What Is Good? Larger Or Smaller Spark Plug Gap?
saadi123
35
Karachi
carz4mod.blogspot.com
Does any one knows that if two identical cars having same features are taken.Only there spark plug gaps are changed. So which one will perform well. The one with larger or smaller gap?
SkYwAlKeR
10,139
300
ePoh ~ malacca
the OPTIMUM gap one wins...
larger gap gives larger stronger spark but less efficient... u'll sometimes experience misfiring...
smaller gap reduces chance of misfiring... but smaller spark with less combustion efficiency...
hachiroku clan
633
73
In laymans terms,
larger gaps: big but weak spark
smaller gaps: strong but covers only in a small area.
U need something in the middle, better stick to the manual, dont temper with it..
donCityZ
2,230
33
Follow car spec la... if u havent done anything to your engine, then there is no reason to change the gap. the manufacturer already study kaw kaw to make it optimum for u. why change?
tofu_manic
1,342
91
"Always check that the spark plug gap is compatible with the engine manufacturers specification. A gap that is too small means that the spark duration will be very quick and the spark will be thin and weak. The consequences of this may be bad starting and high exhaust emission levels. This will result in an increase in fuel consumption. If the gap is set too large, the ignition system will not be able to cope with the demands and a misfire situation will occur. Some wide gap spark plugs have a longer ground electrode to accommodate a wide gap setting. These must be used where specified, as opening up a standard plug to a wider gap setting may result in the electrodes not running parallel to each other. This could result in abnormal and premature electrode wear." - from NGK site
anyways, u could try to open up the gap, mm by mm till u start experiencing misfires, trial n error hehe
OR go for a larger ignition coil + capacitive discharge ignition (e.g. msd 6a) then u can afford to make the gap larger
hi all the masters,im new here,this is my 1st post,hope can hear some idea n opinion.
im old school car fan,i like old school car very much,i have this mitsubishi galant 1.6year 1982.everything is original,didnt change anything at all,even the 24 years old radio is still function well,i just repaint once in 24 years.anything i can do on this car?from outlook to engine,what should i do to make this car better?i hope this car can b more faster,mayb i should do anything on the engine,or...
