VTEC turbo
speed2horizon
2,798
334
1,683
change to emanage blue.....
dynojet power commander can't suit his car....just my 2cent.....
last time i buy 530cc tune with dynojet power commander...all same problem......:bawling:
Thanks bro.. Anymore inputs please...? Otai otai VTECS turbo...
EG6SiRT?
492
vteckiller - Can you install/setup turbosmart Eboost2 fully functional? let me know.
roulette23
43
1,508
Before deciding on a BOT, its best to know what you’ll be expecting from it. The price for investing in this will be high but if such a price yields the power being sought for, then proceed so with a fair bit of warning. I had a BOT built into my Honda VTEC engine recently. The power that it delivers are commendable however, the downside to it was the constant visits to the workshop trying to sort out the issues plaguing such as erratic idling, downshift issues, etc… This will take time to resolve as well as money hence, the price of putting a BOT might not necessarily stop when the turbo is installed but what comes after that.
I had mine installed in a respectable workshop in Section 51A (near Jalan 222). Convinced by the years of experience that they had with modifications, I was hooked on it even when the price was higher compared to other workshops. The layout of the turbo was visually good however, getting it tuned plagued by constant issues that arose after that made the drive less pleasurable after a couple of months of owning it. This persuaded that such constant headache was not well worth it unless it was my ‘play car’ which in this case was not. Naturally aspirated (NA) cars are not made to handle forced induction systems due to certain constraint within the engine which was designed as such. The heat that was increased with the installation of the turbo was at one time so high that the sockets, wires, etc.. just melted away creating a whole host of other issues for me to sort out.
Conclusion, although a thrill to have the pinnacle of what you can possibly do in the car modification sector, it is for me and this is my opinion from actual experience, the end did not really justify the means. Get an actual turbo vehicle meant to be as how it was designed by the OEM and save the headaches & heartaches.
EG6SiRT?
492
plan it the first time properly and change all the wear n tear parts it ll save you a lot of hassle actually. Well, i actually smile when looking back at what i have been through the experience, hassle, the breakdown, all the money spent, and all the sweat n fun i went through with force induction vtec, but whenever i pull and when the G comes, to me.. its all worth it n ill forget bout all the bad experience when im having fun with it. Thats what playing cars is all about... i wont be fun all the way.. :).. till now im still keeping my car and i still cherish all the experience..though it is just a weekend and fun car now..
turbololoy
Dec 11, 2011
11
503
Melaka
Its fun to drive a Vtec turbo, mine is a Honda Civic SiR with a B16a engine. Installed a TDO5 14b turbo, 400cc injectors, changed pistons to 4AGZE Toyota, Eagle connecting rods, etc.. Still running good for after 2 years, street use with Power steering and AC. :)
pijulrs
217
16
U from Malacca?:biggrin:
Got my sms om 30/04/2012..?? Sorry I was having family dinner on the day u called me...
Yup got ur sms.TQ:burnout:BTW...i already found out the solution for my injector problem n my engine now running very good.Had run nearly 2k with this setup n when the boost kick in the vtec.....i fly hahaha...:driver:
pijulrs
217
16
Yes, i am staying in Melaka. The car that i mentioned is i used in Philippines.
Now still using turbocharged car here in Malaysia.
JPJ can allow customized honda turbo engine for street use?
OIC...:proud:IMHO,as long the engine n chasis number doesnt tampered,it should not be a problem with the JPJ.:burnout:
The Marketplace Top Posts
Most modern engines are now electronically fuel injected and have plastic engine covers, this makes engine cleaning much easier compared to older engines with carburetors. I will show you how you can easily clean and shine a modern car's engine bay using only 2 Over-the-Counter (OTC) products.
This is a quick guide showing you how to quickly get your engine bay looking like new again. This guide is more suited towards modern cars' engine bays.
So here have have an engine bay that has never...
