| Welcome | About Us | Forums | Merchandise | Gallery | Contact Us | Register Log in
Private Messages (log in to check) FAQ User Groups Events Calendar Your Profile
Search Member List Knowledge Base MMC Registry
View: unanswered posts | posts since last visit | your posts
Events Calendar
Events Calendar
Mon 19 Jun 2006
Tue 20 Jun 2006
Wed 21 Jun 2006
Thu 22 Jun 2006
Fri 23 Jun 2006
Sat 24 Jun 2006
Sun 25 Jun 2006
Board Index » Tech Support » Taking cut-out out of GSR
View previous topic | View next topic
Author Message
harpa
Posted: Fri Apr 18, 2003 10:32 pm Post subject: Taking cut-out out of GSR
I hear that you can take the cut-out out from a GSR only by taking a screw out from behind the dash somewhere??!?
Is this true? If so where is it? Does it damage it in anyway or just make the ride more fun?
evolution
Posted: Fri Apr 18, 2003 11:30 pm Post subject:
Yes this screw takes out the 180km/h speed cut
Take out your dash, look at the back of it and in the middle at the top there is a screw labeled RSW. Take this screw out and no more speed cut
This screw sends the speedo sensor signal to the computer
Taking the screw out doesn't effect anything else at all
I have done this to about 5 mitsi's
SLOGSR
Posted: Sat Apr 19, 2003 1:02 pm Post subject:
what year is your gsr ?
this only works on the 92-93 models
_________________
Thanks to:
www.speedtechnz.com; Peformance Metal Works; Kelford Cams; Driven performance; Exclusive panel and paint
harpa
Posted: Sat Apr 19, 2003 3:18 pm Post subject:
yer its a 93
harpa
Posted: Sat Apr 19, 2003 3:19 pm Post subject:
cheers guys
David.
Posted: Fri Aug 26, 2005 11:18 pm Post subject:
I have a 1996 Evo 4. How do you take the speed cut out of this?
MAGN1T
Posted: Sat Aug 27, 2005 10:16 am Post subject:
All you need to do is cut the speed sensor wire at the ECU. This applies to all EFI Mitsis from about '90 onwards
Steve
_________________
64 Ford Zephyr 351 turbo, resting ,1.26 Manfield
93 GTO TT 12.1/115
91 GTO TT 12.8/106
87Toyota Townace Royal Lounge (for sale)
93 Telstar wagon (for sale)
93 Pajero 6G74 seized(new toy, need space)
skids2
Posted: Sun Aug 28, 2005 8:17 pm Post subject:
I hope this is for track use?
V R 4
Posted: Sun Aug 28, 2005 9:07 pm Post subject:
Is there any advantage of taking out the speed cut for just daily driving??
I could imagine it could be an advantage if you were using it on the track or maybe down the strip if your car could reach those speeds.
Josh
_________________
Monsterbishi wrote:
responsibility is like wisdom, it's something you grow into, not learn.
Zerolimits
"Nothing But Speed"
"Nothing But Class"
http://www.zerolimits.co.nz - check it out today!
1993 Mitsubishi Lancer Evolution
Monsterbishi
Posted: Sun Aug 28, 2005 9:25 pm Post subject:
Steve
That's the crap way of doing it, which affects moving idle speed control in the process, best way is to interrupt the RSW line.
MMC Member
MAGN1T
Posted: Sun Aug 28, 2005 9:40 pm Post subject:
You're correct, it does affect the moving idle speed control.
I've found it's not a problem and the speed cut removal has worked trouble free in my car for the last 4 years.
It's a free mod and cars with electronic speedos don't have a screw to remove.
Steve
_________________
93 GTO TT 12.1/115
91 GTO TT 12.8/106
David.
Posted: Mon Aug 29, 2005 6:49 pm Post subject:
So if my evo4 has electronic speedo then there is no screw??? So cutting the wire from the ECU is the only way???
Monsterbishi
Posted: Mon Aug 29, 2005 6:57 pm Post subject:
I'm fairly sure the E4 onwards used a electronic speedo signal, and this leads into the next obvious point, why you'd want to do this?, it's faster than the speed limit for any public road motorsport event that your car could enter, is fast enough for a 11 second 1/4 mile pass, and your tyres will be at their limits speed wise too.
MMC Member
afterburner
Posted: Mon Aug 29, 2005 6:58 pm Post subject:
Could you not cut the wire then rig a switch so that it can be on when not needed (ie 99.9% of the time), but you could flick the switch and remove the speed cut when required?
I had thought about doing it, but the only place I'd be needing it would be the back straight at Puke...
_________________
Tredia GLS, 4WD Cordia GSR, VR-4, FTO GPvR, now mighty VW Golf GTi
MMC Member
Location: Formerly Auckland, now Hertfordshire, England
Display posts from previous: All Posts1 Day7 Days2 Weeks1 Month3 Months6 Months1 Year Oldest FirstNewest First
Page 1 of 1
Jump to: Select a forum General----------------News and AnnouncementsGeneral MitsubishiMiscellaneous Automotive Buy/Sell/Swap - Beware Car thieves you are being watched!----------------Mitsubishi Parts/Accessories - FSMitsubishi Parts/Accessories - WTBMitsubishi Cars For SaleOTHER Buy Sell and Swap General Tech----------------Tech FAQForced Induction TechN/A Engine TechTech SupportSounds and Visual Mods MMC Members Section----------------MMC Members GeneralMMC TechMMC Off TopicMembers Rides MMC/General Regional Section----------------Upper North IslandCentral North IslandLower North IslandSouth Island Other----------------Report/Suggestions
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2002 phpBB Group
