silvertop timing belt kit complete set
bera
822
229
1,543
besides that, during u all changes timing belt. did the spare part available for the part like timing belt tensioner pully,oil seal etc for the silvertop engine?
well it depends on your luck actually...some shop sell kits (include all the item needed for the job)...some sell loose part (you have to purchase item per item)...some require you bring them sample (particularly if buying oil seals and bearings)...just ask around and dont forget...insist on original item and keep the receipt just in case and for future reference...happy shopping... :burnout:
ps://i'll ask the shop near my place whether they got st timing belt...going there tomorrow to buy some stuff...
bera
822
229
1,543
update :
just came home from the spare part shop near my place...they say the got it (timing belt) for silver top...but other part like tensioner and stuff i simply forgot to ask...sorry...
feipepe
293
13
balakong
bro,
new updated, today i tries to survey regard the timing belt kit which include the oil seal, tensional pulley, they quote me the price rm170. but the boss spare part shop told me that silvertop engine have 2 version.
1st version
yrs make silvertop before end of yrs 93 consider used 111 pcs tooth on timing belt
2nd version
after yrs make 93 till 95 consider similar with blacktop timing belt, used 110 pcs tooth on timing belt
after they told me, i really confused and how to identify what version of my currently silvertop engine? do u all any ideal or method to differential this 2 version? for those silvertop users, please share.
bera
822
229
1,543
hehehe... i thought you settle this issue already...i ran a search...yes st does come with 2 type of timing belt...
these are the st timing belt part number...
13568‑16030 (06/1991 - 04/1992)
13568‑19035 (05/1992 - 04/1995)
even though the teeth are the same...the part number is different...
13568‑19185 <---bt timing belt part number
just to be safe i suggest that you take out the old one...and copy down the part number written on the belt...better yet...bring it to the spare part shop as a sample...
you can search all the parts here...
http://www.toyodiy.com/
jimmylai3333
Jun 6, 2012
5
hi all,
i am a new user who using blacktop auto engine.
which shop do you guys can recommend to service engine like changing timing belt , oil seal, water pump and etc ??
do you guys have any idea ekzos pipe should i use ?? 2 inches or 2.25 inches or 2.38 inches??
pls advise ... tqvm ..
from
jimmy
feipepe
293
13
balakong
hi jimmy,
for workshop, u may search thro the forum. because already a lot of ppl post. for blacktop auto, better used 2.25 inch as your piping setup. because more commercial and economy and suit for auto.
D7zul
2,697
848
Shah Alam
hi all,
from
jimmy
i think the stock exhaust is good enough.. since u have an auto transmission.. i think it's 2.25 inch
bigger exhaust tend to push the power band upwards.. so, u'll feel lack of power if in stop & go traffic..
workshop have a lot in klang valley.. which area r u?
:biggrin:
---------- Post added at 09:36 AM ---------- 6 hour anti-bump limit - Previous post was at 09:33 AM ----------
if in KL.. HAZ Garage..
u can google it :wink:
The Marketplace Top Posts
Dear sifus and otai
Need some advise here,my ride is proton persona 1.6 auto,is it recomended to change to open port air filter?currently i am using drop in air filter.What is the pros & cons on this?,also is it worth and recomended to add e-manage if my ride is standard and just changed the exhaust system only?your comment is highly appreciated :burnout:
