Radiator water?
TiBuN
Penang / BM
Which water is good ?
Distilled water ?
Mineral water ?
Tap water ?
Diamond filtered water? :P
distilled water doesn't have any minerals, pure 99.9% water, hence, rust won't be that easy to develop.
Originally posted by silentkiller@Sep 21 2004, 01:27
Distilled water + coolant, tambah water wetter lagi sedap!
Coolant & Redline water wetter different???
I thought water wetter considered as a coolant itself?
Correct me if i'm wrong.
nope, to be more specific, water wetter is like a additive to the coolant, that is why it comes in a small packaging form.
My water wetter comes in quite a large bottle, i think 250ml, not very sure. And according to the instruction, I should pour the whole bottle into it, is there any problem?
That means I need to get coolant before pouring? Luckily I still haven't use the water wetter yet....
On a sidenote, please recommend a coolant? NASA? Hehehe
i use redline, what brand did u bought?
Water wetter doesn't have anti-rust or anti-frost agent in it. That's why you need a bottle of coolant even if you have water wetter. Written on the bottle, best result is to use water wetter with water only but in asia, we can live without anti-frost but i wouldn't wanna see my radiator rust.
A bottle of Redline water wetter is 355ml.
My cup of 2cent Wwater wetter :D
Originally posted by silentkiller+Sep 23 2004, 00:44 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (silentkiller @ Sep 23 2004, 00:44 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-TiBuN@Sep 22 2004, 19:30
i use redline, what brand did u bought? [/b][/quote]
Mine is also Redline. thinking alot of stuff because scared of wasting the water wetter, ain't cheap that's what I should say.
So it's just coolant + ww, no problem
Another question : Do you bleed(flush) your radiator or do you mix with the original?
Some knowledge shared by my co facility guy. My co is using DI water (Deionized & distilled water) for product process. Since the water been deionized and filtered away all the minerals, it AKA "hungry watar". It's more corrosive than normal water. When DI water gets contact with any metal, it will eat out the metal very fast. Dunno how true is it.
u must understand wat causes rust aka oxidation. OXYGEN itself! therefore, water in any form will cause oxidation/rusting. besides, there's no truth in saying distilled water has better cooling efficiency or prevent rusting coz distilled water(pure H20) has boiling point of 100 celsius where else 'tampered' water with all those minerals and other particles have a slightly higher boiling point. just a simple experiment. if u boil distilled water and test the temp, u will find its close to 100 celsius where else u try boil water with some salt in it, u will find the temp boil at 120 celsius more or less. now we talk about coolant. its essentially the liquid that jacks up the boiling point of water and therefore ur car stays cool. plus it prevents rust from forming but u must bear in mind it minimises, not eliminates. u will find that even with coolant, your radiator and other internal parts will still suffer from rust, moreover if the coolant content is already low inside. a point to note though, coolant does not remove rust, it just minimises the rust and prevents it from rusting further.
Originally posted by TiBuN+Sep 23 2004, 18:43 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (TiBuN @ Sep 23 2004, 18:43 )</td></tr><tr><td id='QUOTE'>
@Sep 22 2004, 19:30
Another question : Do you bleed(flush) your radiator or do you mix with the original? [/b][/quote]
off course do full flush b4 masuk ur coolant + ww, since oledy spend so much why no go the last mile :D btw im using benz coolant(blue colour), so even in the hot afternoon when i boost my gsr, temp still ok.
how to flush then? last time i got conned by stupid petronas petrol station ppl... bought their expensive coolant which my foreman told me can bought it outside with half of the price... hai~
cool down ur engine
open ur radiator cap
unscrew the plastic bolt (right hand lower of ur radiator - proton car)
let it drain
run down fresh water (let it flush the leftover deposit)
screw back the plastic bolt
put ur coolant 1st
then top up with fresh water
start ur engine (without the radiator cap)
top up water if necessary
when the water in the radiator start to heat (U can see the water evaporates)
close the radiator cap
and check for leakage from the plastic bolt
rev/drive ur car, check for leakage again
am i rite sifus?
Originally posted by prodigy+Sep 23 2004, 23:19 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (prodigy @ Sep 23 2004, 23:19 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-GRexer@Sep 21 2004, 17:09
u must understand wat causes rust aka oxidation. OXYGEN itself! therefore, water in any form will cause oxidation/rusting. besides, there's no truth in saying distilled water has better cooling efficiency or prevent rusting coz distilled water(pure H20) has boiling point of 100 celsius where else 'tampered' water with all those minerals and other particles have a slightly higher boiling point. just a simple experiment. if u boil distilled water and test the temp, u will find its close to 100 celsius where else u try boil water with some salt in it, u will find the temp boil at 120 celsius more or less. now we talk about coolant. its essentially the liquid that jacks up the boiling point of water and therefore ur car stays cool. plus it prevents rust from forming but u must bear in mind it minimises, not eliminates. u will find that even with coolant, your radiator and other internal parts will still suffer from rust, moreover if the coolant content is already low inside. a point to note though, coolant does not remove rust, it just minimises the rust and prevents it from rusting further. [/b][/quote]
so the bottomline is to use normal tap water? :unsure:
A thread every 60 seconds
