no problem... rear disc brake is not in JPJ's checklist...hi..wanna ask..if iswara installed with rear brake got any problem with jpj or police??just curious...
Wat brake pad u using now? Skim disc rotor will eliminates wheel vibration under braking. Its reccomended to use new/even brake pads after skimming.owh..thanx for the info..now im having problem with my brake..so im already change brake pad a few months ago.but my brake still not sharp as before.some ppl suggest me to skim disk brake..is it ok to skim disk brake?what pros and cons if we skim disk brake??
Skim disc brake is a service. Change bigger brake set is an upgrade. If u feel stock brakes are good enough for u, save ur money and jz skim ur disc rotor. If u butt itchy and got extra money can go for larger brakes.sifus.. just wondering..
skimming disc brake or change to bigger brake is advisable?/
any pros and cons?/
oke.. now i understand..Skim disc brake is a service. Change bigger brake set is an upgrade. If u feel stock brakes are good enough for u, save ur money and jz skim ur disc rotor. If u butt itchy and got extra money can go for larger brakes.
evo?/ like that is more than i needed..Go for evo brake system. Help u solve all braking problem.
nothing is overkill for braking system... rear disc brake are very useful particularly at speeds above 140kmh...evo?/ like that is more than i needed..
wat bout just a normal wira 1.6 ones..
haha..
let say used the vr4 or evo, can just used the front side, doesn't need to upgrade the rear to disc brake also can rite? a normal 1.3 with 4 disc brake.. walau..
oke bro sky..nothing is overkill for braking system... rear disc brake are very useful particularly at speeds above 140kmh...
if ur mechanic can make it fit ok lo... make sure front and back same PCD... or else u have to find rims with 8 lugs (2PCD)...oke bro sky..
tankiu for the good info..
mayb change to just a wira one,
with a 100 pcd ones..
so can use many nice rims..
ehehe..
ya, thank you for the advise..if ur mechanic can make it fit ok lo... make sure front and back same PCD... or else u have to find rims with 8 lugs (2PCD)...
