crazy89
Sep 22, 2010
11
cyberjaya
owh..thanx for the info..now im having problem with my brake..so im already change brake pad a few months ago.but my brake still not sharp as before.some ppl suggest me to skim disk brake..is it ok to skim disk brake?what pros and cons if we skim disk brake??
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
Wat brake pad u using now? Skim disc rotor will eliminates wheel vibration under braking. Its reccomended to use new/even brake pads after skimming.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
sifus.. just wondering..
skimming disc brake or change to bigger brake is advisable?/
any pros and cons?/
Skim disc brake is a service. Change bigger brake set is an upgrade. If u feel stock brakes are good enough for u, save ur money and jz skim ur disc rotor. If u butt itchy and got extra money can go for larger brakes.
series5401
373
17
Kuching
oke.. now i understand..
tankiu sifu sky..
:adore::adore::adore::adore::adore:
carlyap
728
Go for evo brake system. Help u solve all braking problem.
series5401
373
17
Kuching
evo?/ like that is more than i needed..
wat bout just a normal wira 1.6 ones..
haha..
let say used the vr4 or evo, can just used the front side, doesn't need to upgrade the rear to disc brake also can rite? a normal 1.3 with 4 disc brake.. walau..
khguan
4,818
26
Seri Kembangan
fotopic.net
i got 1 set putra 1.8 front brake caliper n disc set with me now... anyone interested pls contact me direct. 012-270 8685 (Guan)
Very good upgrade for wira/satria 1.3/1.5
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
haha..
nothing is overkill for braking system... rear disc brake are very useful particularly at speeds above 140kmh...
series5401
373
17
Kuching
oke bro sky..
tankiu for the good info..
mayb change to just a wira one,
with a 100 pcd ones..
so can use many nice rims..
ehehe..
series5401
373
17
Kuching
if ur mechanic can make it fit ok lo... make sure front and back same PCD... or else u have to find rims with 8 lugs (2PCD)...
ya, thank you for the advise..
now adays oil nait harga..
so not many people wana to press the pedal till the floor..
ahahaa..
aaaeye
Nov 24, 2010
13
Hi all..nubie 4g15 here.. What the long time to finish the reading..btw, can all sifus conclude the best setting to enhance performance??
1) Plug
2) Cable plug
3) Timing Belt
4) Cam/Crank pulley
5) Camshaft
6) Flywheel?
7) Any extra 'ingredient'
Will u?? :biggrin:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
1) Plug
2) Cable plug
3) Timing Belt
4) Cam/Crank pulley
5) Camshaft
6) Flywheel?
Will u?? :biggrin:
timing belt cannot help increase performance bro... using good ones can help improve reliability only...
series5401
373
17
Kuching
1) Plug
2) Cable plug
3) Timing Belt
4) Cam/Crank pulley
5) Camshaft
6) Flywheel?
Will u?? :biggrin:
ya.. agree with sifu sky.. timing belt can increase anything.. your 4g15 is carb or fuel inject bro?/
It’s one of those scenarios that you always wondered about but never really got the chance to see played out. Sure cars going sideways are a thing of art but even their two-wheeled counterparts can get that back end out and that is sublime art.
So here we have a Mazda RX-7 with a 375hp Corvette V8 under the hood going up against a 2005 Kawasaki ZX10 with 175hp. Taking the reigns of the RX-7 is pro race car...
