Blue streak belongs to Goodyear already. The time when I was using I think they acquire the brand. However they have change the pattern too.Sorry, didn't follow that thread last time.
Seems like you have a good history with using Good Year tyres. As for Blue Streak, I never heard of that before.
You never go as far as extreme or semi-slick? But I can probably tell that you are more towards practicality than going all out for racing.
Fleva should be a higher grade than RE003 right? Max category? Replacement for S-Drive...
Actually wanted to keep 2pcs for Hyundai Sonata use, but tyre rubber compound harden already. 2 pcs even the sidewall crack when they were compress to remove from the rims, so threw them all away.....lolvr2, your old tyres leh? wanna sell?
At first not expecting much since price so budget, but after using in the rain and did push it a little seems quite sure footed holding down the VR power....Rm220? Tread wear of 500...
Wow.. where you got such a good deal..
Continue to share with us on this tyre..
do some speed test too
Blue streak from what country? In a way, the thread looks slightly similar to ATR Sport.Blue streak belongs to Goodyear already. The time when I was using I think they acquire the brand. However they have change the pattern too.
When I was using looks like this..Blue Streak Stiletto
Now looks like this...Now called Goodyear Blue Streak Stiletto
Nope, don't intend to use extreme or semi slick. Tyres are expensive, not comfortable, noisy and not good for wet road. I use my car for daily so usually is UHP or Max performance tyres are the way to go.
Yoko Fleva V701 replace S Drive are UHP if not mistaken. V105 still their flagship model. Yes, same as RE-003 as to me BS still have other higher models. That is why when PS4 tested against RE-003 just because they are selling well in the market along PS3.....lol
Blue Streak is local, if not should be from one Asean county under Goodyear, as now in Goodyear MY website dy. Very cheap these tyres, my size 215/45R17 also around RM210 or so only....Blue streak from what country? In a way, the thread looks slightly similar to ATR Sport.
Might be a bit hard to compete if the Fleva is more expensive... But not to the price of PS3 isn't it?
Wah me still a long way to go with my current tires, maybe another 2+ yrs before I need to change so don't hold your breath!Fleva did not materialize, maybe you can test and review......hhahahah
Under RM300 for 215/45/R17 is very cheap. Somehow, you often managed to find cheap budget tyres and yet they still serve you quite well despite not coming from a famous brand. But then, the Viking City Tech that I am using is also doing quite well. Cheaper than Goodyear duraplus and also more reliable... Able to hold in air pressure well too unlike the Goodyear which always seems to need pumping.Blue Streak is local, if not should be from one Asean county under Goodyear, as now in Goodyear MY website dy. Very cheap these tyres, my size 215/45R17 also around RM210 or so only....
Fleva should be around PS3 pricing, but depends on the sizes.....
VR power, at what speed is this power?At first not expecting much since price so budget, but after using in the rain and did push it a little seems quite sure footed holding down the VR power....
aiya should have told me, my previous brigdestone on my perdana also cracked, used to glue it back & it lasted till I sold the carActually wanted to keep 2pcs for Hyundai Sonata use, but tyre rubber compound harden already. 2 pcs even the sidewall crack when they were compress to remove from the rims, so threw them all away.....lol
GT Radial HPY more than RM300. Is Blue Streak Stiletto and this Land Golden close to RM200 only.......lolUnder RM300 for 215/45/R17 is very cheap. Somehow, you often managed to find cheap budget tyres and yet they still serve you quite well despite not coming from a famous brand. But then, the Viking City Tech that I am using is also doing quite well. Cheaper than Goodyear duraplus and also more reliable... Able to hold in air pressure well too unlike the Goodyear which always seems to need pumping.
So, Fleva is like a direct competitor to PS3...
VR old dy. not power like your Evo. Got speed cut how to reach 300.....lolVR power, at what speed is this power?
300km/hr?
can hold?
