New Tyres for VR
kurt_629
872
54
johor
Rm220? Tread wear of 500...
Wow.. where you got such a good deal..
Continue to share with us on this tyre..
do some speed test too
Sorry, didn't follow that thread last time.
Seems like you have a good history with using Good Year tyres. As for Blue Streak, I never heard of that before.
You never go as far as extreme or semi-slick? But I can probably tell that you are more towards practicality than going all out for racing. :biggrin:
Fleva should be a higher grade than RE003 right? Max category? Replacement for S-Drive...
Blue streak belongs to Goodyear already. The time when I was using I think they acquire the brand. However they have change the pattern too.
When I was using looks like this..Blue Streak Stiletto
Now looks like this...Now called Goodyear Blue Streak Stiletto
Nope, don't intend to use extreme or semi slick. Tyres are expensive, not comfortable, noisy and not good for wet road. I use my car for daily so usually is UHP or Max performance tyres are the way to go.
Yoko Fleva V701 replace S Drive are UHP if not mistaken. V105 still their flagship model. Yes, same as RE-003 as to me BS still have other higher models. That is why when PS4 tested against RE-003 just because they are selling well in the market along PS3.....lol
vr2, your old tyres leh? wanna sell?:smokin:
Actually wanted to keep 2pcs for Hyundai Sonata use, but tyre rubber compound harden already. 2 pcs even the sidewall crack when they were compress to remove from the rims, so threw them all away.....lol
At first not expecting much since price so budget, but after using in the rain and did push it a little seems quite sure footed holding down the VR power....:driver:
RENESIS VIII
7,063
950
Ipoh
Blue streak from what country? In a way, the thread looks slightly similar to ATR Sport.
Might be a bit hard to compete if the Fleva is more expensive... But not to the price of PS3 isn't it?
Blue Streak is local, if not should be from one Asean county under Goodyear, as now in Goodyear MY website dy. Very cheap these tyres, my size 215/45R17 also around RM210 or so only....:driver:
Fleva should be around PS3 pricing, but depends on the sizes.....:driver:
RENESIS VIII
7,063
950
Ipoh
Under RM300 for 215/45/R17 is very cheap. Somehow, you often managed to find cheap budget tyres and yet they still serve you quite well despite not coming from a famous brand. But then, the Viking City Tech that I am using is also doing quite well. Cheaper than Goodyear duraplus and also more reliable... Able to hold in air pressure well too unlike the Goodyear which always seems to need pumping.
So, Fleva is like a direct competitor to PS3...
DanzEterna
15,911
3,371
www.primeperdanaclub.com
aiya should have told me, my previous brigdestone on my perdana also cracked, used to glue it back & it lasted till I sold the car :rofl:
teh 500 treadwear rating impress me... :biggrin:
sure got 225/50-17 rite? if sifu use long term with minimal problem, i might try to find this one on next tyre replacement...
hon_cs
251
43
3,028
Ipoh
bro VR,
I think saw your car few times around PJ old town near Chen Moh chinese school. Was it you always makan there? What I often see about budget tyre is usually it tends to wear and crack a lot faster than expected. I'm also using GT Radial HPY for about 1.5yr. Can see fine lines on the shoulder area. Just normal drive and seldom attach corner.
GT Radial HPY more than RM300. Is Blue Streak Stiletto and this Land Golden close to RM200 only.......lol
Yah! Fleva more to PS3 and RE-003 loh
VR power, at what speed is this power?
300km/hr?
can hold?
VR old dy. not power like your Evo. Got speed cut how to reach 300.....lol
Can hold means push a little in corner, unlike previous blue streak can drift......hhahhahahha:rofl:
Hi there,
I would like to know where can I purchase the overhaul set for 4G92 DOHC MIVEC(CA4A). IS THE ROCKER COVER RUBBER SEAL THAT I'M CONCERN ABOUT. Others I can use 4G93 gasket set.
Pls PM me. Thanks
