need help: Honda city 2008
dean_nojum
40
1,508
johor
I drive Honda City 2008 (old model). When braking from 90-100kmh, i felt vibration on brake pedal but not on the steering wheel. Alignment and balancing had been done several times. The brake pad had been checked by Honda and found not faulty. Hope u all can help. thanx
Fairlady350
72
5
1,508
Chances are i think your disc rotors may be worn out or just damaged. Send it to the workshop and tell them that you want to perform disc repair like skimming and that sgould do the trick.
jsdaemon
137
11
i have experienced this before.... just ask the SC to skim your disc rotor...
kian27
62
5
1,508
same comment...mostly is bcuz of ur disc rotor...usually if when u press pedal n feel vibrate den is tis cause..jz my view..
Hey members,
I am a Malaysian. I used to be a student in USA and now I have graduated with a Master degree. I have then work here for more than a year. I own a car in here for almost 3 years and I would like to import it back to Malaysia. My car is a LHD car. 2008 Mitsubishi Lancer Evolution X. Anyone know the procedure to import it back to Malaysia? Also register to drive on the road. The cost, etc?
Please help! Thanks a lot.
