Kenari Engine Vibration Help!!!!!!!
MaxD2
342
5
kl
Any Sifu here can help me??? This problem already tight me around half year . Still cant solve it, hope Sifu here can help me..My engine when at N position , it was litte bit vibration ...but put on D position , it was vibrate like hell. ... Some more when engine cold it was serious vibrate....apply brake till stop also vibate.........Haiz....
Already change perodua genuine mounting... change ALL ... BUT THE PROBLEM STILL SAME..
My kenari model is 2002 ..auto..
is that throttle body problem????????? but when hot day ..the vibration is less ... why????
Pls help~~~~:adore::adore::adore:
kelisa6009
17,144
40
Penang Kia
did u change or service your air filter?
lonelylilpig
832
33
Time to check on throttle body !!
MaxD2
342
5
kl
already change 3 mounting........... genuine part from perodua.........
already change throttle body also....................
cant solve the problem..also.
Need Sifu Help....
lonelylilpig
832
33
Wah haven't rectify the prob straight change throttle body ........ Ouch
Anyway is your engine check light on. If yes then remove negative terminal 4 5 mins then fit it back. If vibrate again then MIGHT be your transmission torque converter facing slippage. If wat i suggest is wrong , don't poke my backside ......
lonelylilpig
832
33
can it be the exhaust sensor ?
Exhaust sensor first there might be lights on engine check light, second damn lot of black smoke, third will vibrate more but not as worst as engine mounting kong or miss firing does.....
MaxD2
342
5
kl
no check light come out............ already scan with computer , no fault code...........
Haiz .......... pening pening..:banghead::nurse:
kelisa6009
17,144
40
Penang Kia
where got poison...only help ppl to safe cost nia
