Brembo Sport Drilled Disc Rotors
Lancer Evo 5GSR/6/7/8
Features:
Front RM1800(last set)
Diameter : 320mm
Thickness : 32mm
5Holes
Rear RM1700(last set)
Diameter : 300mm
Thickness : 22mm
5Holes
Front+Rear = RM3400
COD JB/Malacca
Skynet Courier Service Available
PM or Contact 016-7442406
Kaitospeed Performance Autoparts
Features:
- Forged from high-carbon cast iron
- Cross-drilled design evacuates heat and refreshes brake pad surfaces for better bite
- Drilled surface also wicks water away from the rotor surface, noticeably improving brake response in wet weather conditions
- Directionally vented for maximum grip and centrifugal evacuation of heat gasses
- Work with the stock calipers
- European TUV certification for quality
- Reduces braking sound through the higher damping coefficient of carbon steel discs
Diameter : 320mm
Thickness : 32mm
5Holes
Diameter : 300mm
Thickness : 22mm
5Holes
Front+Rear = RM3400
COD JB/Malacca
