If i'm not mistaken, my car has 3 hoses connected to the radiator, all 3 are about quite new. I don't think it is the hose. But, now I suspect it could be the plastic bottom cover. Few months back, i change the top plastic cover. So, maybe it could be the bottom. But then again, if it leaks, it should be leaking everytime. But in my case, it is not everyday.confused-loose hose clip
-cracked hose
-leaking radiator (cracked plastic top/bottom cover)
Nope, he did not use this at all. I am quite fed up with this foreman already. He is quite famous in JB drag scenes and so i think he not serious in doing these small jobs. I told myself not to go to him again. disappointed
for my car, optimum level is almost close to middle of cold and hot, slightly more to the cold side. recently, i drive very slowly so the temperature is only at 1/3 of the meter from cold. it doesn''t reach the optimum level. As u said, it will leak when engine is hot. do u mean hot as in at any temperature or optimum level? I'm sorry if i got your whole idea wrong. not very knowledgeable in all this.check your hose (lower part of radiator) it will leak when engine hot. best is to check after engine temp reaches its optimum temp.
I hope some one can recommend a good and honest foreman in JB. Really need to get it done before it gets worse and make me pay more. thank you.
---------- Post added at 09:54 PM ---------- 6 hour anti-bump limit - Previous post was at 09:51 PM ----------
-cracked hose
