Help needed on my B20B !!!
Blue Little Lorry
572
17
I just bought a B20B engine half-cut, supposedly built by Feel's.
After re-building the engine and dyno tune, the result came out to be 190 HP at 7K RPM - 20 KG of torque. The dyno graph doesn't seems right. After VTEC engage the power band seems to drop a little.
My power topped at 190 HP @ 7K RPM and the power band drop after that. Along the way, it seems struggling to go up. The entire graph seems sluggish.
Here are my specs:
Head
Type-R with port and polish by Feel's supposedly.
B16B Type-R cams, valve springs & retainer.
Feel's cam pulley.
ARP bolts.
NRG plug cable.
Iriway spark plugs.
Block
B20B with block guard from Feel's supposedly.
CP Pistons 84.5 mm.
Balanced crank.
Standard con rod.
Standard casket (reduce one layer).
Others
Type-R in-take manifold (ported)with Super 90 70 mm throttle body.
F22C injectors.
Standard fuel rail.
Feel's 4-2-1 extractor.
Straight flow centre piping 2.5 inches.
Sard MIG muffler.
Feel's ECU.
E-Manage.
Simota air filter with guppy air ram.
I am planning to change my air filter to K&N.
I am planning to upgrade my cams, valve springs and retainer to either BC or Juns.
Will this two help improve my engine's performance ??
I donno what I am gonna will help or not, still trouble shooting.
Hope to get some valuable comments to improve my ride. Thanks guys.
deacon
Senior master debater
1,167
30
Swap ECU and get a retune.
E-Tech
1,115
256
3,183
Johor
Before u change cams.....
1. During dyno air fuel ratio at wat value?
2. Hv you set you type r cams?
Might need to do some adjustment
To push the power band up to 8k+
caleb_5375
1,293
typeR cams should be making power until near 9k..but different engine have different engine characteristic bro...cams will surely makes power ...but i wuld suggest u get a 4-1 header such as b18cr header or mugen type...last time i use 4-2-1 with skunk2 pro3 cams oso give less then 200whp..but after change it to 4-1 it gives a good high rev...
u can try by change the header first...butneed retune ur mapping coz the flow of exhaust diffrent d..u will feel some jerk near the vtec engage point but tat is all okie geh..coz need remap..
lucian^^Gk
115
5
Sarawak
izzit the b20b is a non-VTEC engine ???
or am i missing sumthing here!!!
pls enlighten me...
What’s the deal?
Edaran Tan Chong Motor Sdn Bhd (ETCM) today proudly announced the global premiere of the new Nissan Teana NISMO Performance Package. The NISMO Performance Package for the Nissan Teana is the latest upgrade option for Nissan models in Malaysia, with 2 packages to opt for; NISMO...
