Haltech Platinum Series
lozo
897
7
5,018
yeup correct. why there is different...hmm sorry couldn't figure out. maybe to compensate the injectors delay. will do research on it
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
hehe... i have played a tiny bit with the injectors timing delay... the air fuel ratio will show a temporary rich condition before going full lean "due to decel cut" after letting off the throttle. Is that a good thing to do? If not mistaken that shouldn't be it rite? carbon deposit may build up over time and yet i assume the additional fuel before decel cut is good for cooling down the cylinders... unfortunately no loud popping sound between gear shifts...
lozo
897
7
5,018
i don't think there will be any carbon build up due to temporarily rich condition. at least it assist cooling though
Syahz
484
21
Australia
How fast you can tune on the dyno?Short time,reliable and Quality.
Using the Haltech Duel Channel Wide Band and put your AFR target...run it.
You can run on the road or on the dyno if you have a facility your place.
Do profesional tuning on your self.Every time Innovative.
Syahz
484
21
Australia
Good News For RX7 and RX8 Club.
The Platinum Sprint RE
Engine Suitability:
• 2 Rotor Engines - 2nd Generation RX7 (FC3S)/Turbo II, 3rd Generation RX7 (FD3S) and RX8 (SE3P)
• Normally Aspirated or forced induction
• Load sensing by throttle position or manifold pressure (MAP)
• Sequential Injection
• Distributor ignition systems or multi-coil systems
Trigger Types:
• Reluctor
Trigger Patterns:
• Mazda Rotary Multitooth 24 and 2
• Mazda Rotary RX8
Pls Contact Your Haltech Dealer for more Information
Syahz
484
21
Australia
Good News
For all waja engine and campro cps or non cps can running perfect with Sprint 500.
Pls contact your Haltech Certified Tuner.
Syahz
484
21
Australia
Platinum sprint 500 on Toyota Lexus 6cylinder VVT
Official Haltech Forums • View topic - Lexus IS300 Turbo Sprint 500 ecu
---------- Post added at 11:01 AM ---------- 6 hour anti-bump limit - Previous post was at 10:49 AM ----------
VR6 running Haltech E8 semi-sequential.(6cylinder)No dramas.Can use for Perdana V6 turbo.
VR6 engine Je Pistons, Eagle rods, T3 60-1 Turbo Haltech E8 semisequential injection wasted spark ignition on stock coil pack
373WHP@ 1Bar boost
YouTube- Corrado VR6T 0-260 km/h
Airmund
14
1,503
Hey Syahz, PMed you regarding kelisa and haltech Sprint 500. ANyone here knows if Kelisa 2nd generation can tune ignition timing with Haltech 500? Coz i heard cannot tune with Emanage since using cam sensor.
ALso, will the Haltech 500 work with 3 cylinder supercharged Kelisa? Thanks for any help.
Cheers,
Ed
Syahz
484
21
Australia
Cheers,
Ed
No worries for kelisa 3cylinders.we know the trigger type and set up.May be u can ask the haltech Tech for the clear message.Or u can ask your nearest dealer.
Syahz
484
21
Australia
350Z already use Pro Platinum plug in.And more function for tuning.
You can refer with super duper dealer Haltech or Haltech Certified Tuner.
dear members..pls help me..what is the problem for my civic fornt disc brake?the front disc left side have scratch..i already change to another caliper complete with another nice disc..but the problem still same...my mechanic said that was brake masterpump problem..is that true?pls help me....
