Greedy E-manage
wwilliamm
Jul 12, 2012
47
6
508
Dear sifu's, just want to double confirm that myvi 1.5 ECU cannot be remapped by e-mange, em-con or whatsoever right? As i've read many other post before that the DVVT function will somehow takeover the remap settings and therefore the settings will run. Is it true? :confused:
weaponzero
51
508
Philippines
dear sirs! does anyone here have used the latest e-manage blue "smaller"? it says it has direct usb functions, but where can i find the software? thanks
ixeo
4,788
3,080
KL, Malaysia
Can.. it will work but only open loop.
drill
617
12
5,018
Damansara
hi guys... it seems like this is an old thread... just reuse it as it has the title i need.
im currently trying to figure out this problem.
my engine has only open-close tps, not the variable tps (only 0v-5v). Also goes for my air flow sensor. But both of it is in reverse order. ie off is 5v, and on is 0v. correct me if im wrong, but emanage blue can handle that right? just select the reverse option for the tps. correct arr??
and as my tps is only open-close, so in the airflow map... it doesn't read the throttle movement on table. it reads only the rpm. my fren says that by adding the map sensor, i can eliminate the problem. is that true? i just don't see the logic(me very blur now). can anybody care to explain?
blitz
42
14
5,008
definitely got fake units, dats y i buy from people i trust jer. err, u need one ke?
yup.. i think i need one for my Euro R but scared to buy coz of the fake ones... Do you know where to get the ori ones???
penagihdadih
117
17
518
Shah Alam
Im opting for emanage ultimate because it offers 2 fuel mapping. But still, emanage ultimate also got fake one. Y lar like this..
Maybe one day I'll go nuts and buy a fake emanage ultimate.
egb18c
922
94
kuantan
just wandering whether we can replace the stock narrowband o2 sensor with wideband sensor and hook it up with emanage blue.
So the engine will run with wideband sensor only.
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
i know i guy told me only opening the e-manage and check the chip can determine its original. the chip has japanese brand printed on it.
xtremeleo
3,247
464
5,183
for d bogus emamage issue, just get a unit from a trusted seller.. ive found bad units in customers' cars dat were bought in famous big names around sunway, so be very careful not to trust expensive price tags. the ones i ordered, installed and tuned has been good so far. pm for more details, tq
