Greedy E-manage
wajunk
63
508
Selangor
yup..e-manage got fake one..
not sure how to differentiate with ori..:confused:
thats y im using the M7..hope mine is not fake one..huhhu
bera
822
229
1,543
i reckon the new emanage (the smaller) still doesnt have fake...if you going to buy 1...insist on that one...
penagihdadih
117
17
518
Shah Alam
i saw just now somebody sell e-manage blue with complete set only for 700.. That one is totally fake one.. Does anybody know the flaws of the fake one? Does the fake one working?
xtremeleo
3,247
464
5,183
one major pita is tjey wont hold their tune points when the battery is removed,some other problem exists but dis ome irritates me the most
Jac83
164
54
Hijack the thread a bit hehe, my e manage blue is working fine except after installed my ride is having difficulties in starting. Need to crank quite a few times before start. According to my tuner, this can't be helped due to my 390cc injectors bigger than stock. Below is my engine: spec.
B20b bot
Gsr injectors 390cc
Garrett ar60 ball bearing turbo
Rest stock standard
Afr tuned at 11
Any feedbacks will be much appreciated.
Jac83
164
54
Yea stock fuel pump. During tuning can see Afr at the rich side, no signs of lacking in fuel pressure or volume even during full boost at 0.7 bar. Could it just be the emanage's common issue? Any other users out there having the same issue?
SuperVelocity
5,000 RPM
Feb 27, 2012
5,365
6
638
B20b bot
Gsr injectors 390cc
Rest stock standard
Afr tuned at 11
maybe your starter got problem?
ixeo
4,788
3,080
KL, Malaysia
if you disconnect the emanage does it start with 1 turn? yes I know it will be pig rich but the engine won't explode.
AFR at 11 is on the rich side as well. hmm.
ixeo
4,788
3,080
KL, Malaysia
u cant start the engine when the emanage is taken out, its in the wiring
thanks for heads up. I thought the wiring was plug and play using harness. :hmmmm:
xtremeleo
3,247
464
5,183
the emanage can be taken out for safety keep, but the unit itself isnt pnp, u need to wire it in, its a piggy bag, not a replacement for the std ecu
The Marketplace Top Posts
Hi guys, Good Day!
Just want to ask do you guys know where to do body kit like plastic? i dont know what you call that but i have seen some of the car like evo and M5 do it...is in black but plastic look alike....
