Gear SERIOUS problem .. urgent pls
anfernee
246
I think syncro in chinese call "thong nga" or something like that.. that's what I always hear those mechanic say.. :P
@zri
1,357
but d problem is.. when i switch off d engine i can easliy change every single gear... when i start d engine again.. d prob shows up... ;(
Norns
497
the 'thong' issit pronounce as 'thong'(sup in english)
now im smooth adi except gear 2 > gear 1
just wan to confirm, does clutch pad will effect ur gear to be similar to this ???
coz im taking a risk to change it this friday
K_Takuya
Moderate Moderator
Sep 1, 2005
1,954
153
Limau bali,Ipoh
i think to shift down to gear 1..it is advisable to do when in full stop.. gear 2 is strong enough ...why need gear 1 while moving? the rpm will be quite high while moving..
LanEvo
215
I think his problem is hard to shift gear up and down (1 > 2 or 2 > 1), especially when high RPM or car moving fast..
ikan_laga
171
Penang
izit a real problem??i tot any car would do the same..why wanna downshiftting to 1st gear while u moving?1st gear only use to initiate the car to move only..i read dat sumwhere..
sn_ting
104
snting.blogspot.com
Normally clutch finished if difficult/hard for u to shift gear from 1>2>3 and after u shift the gear ur car felt like lossing power coz when ur clutch pad "kong" already and cannot grab the flywheel and cause clutch slip or more seriously cannot grab the flywheel at all and last ur clutch will burned.
That's my experience...
dammm... all these while repairing other car for friends/family it doesn't create such a headache to me...
but my own car pulak acting up....
the problem is one night while reversing and parked my car at my porch... the engine dies (been hearing rough idling just before that)
car can crank...but no spark coming out at spark plug cable...so confirm ignition problem...
since normally the distributor was main culprit...i've replaced it with recond unit new....but to no available...the...
