Gear SERIOUS problem .. urgent pls
Norns
497
I have problem with my gear all of sudden . The problem occur as i having difficulty push my gear 1 and gear 2 . When i need to shift from gear 1 > 2, or gear 2 > 1 its very hard to push the gear ......
I just bring it to mechanic for checkup , and he just put some sort of 'cream oil' at the gear there around the engine .... bcos i just did T-Body wash, thats y they no oil adi ..
After that, i notice that i easier to put gear 1>2, or gear 3>2 .... but when i need change to gear 1 is very hard ....
My car must be super slow or until ALMOST stop, then onli it allow me to push to gear 1 .... or else its very very hard to push as if sumthin is blockin the way ..
What cause this actually ? i never faced this before ler ... The mechanic told me its either my gear oil or clutch problem . But i just change my gear oil recently
Could it be cluth or wad
Need urgent help from u guys ... guys i;ll have to bear with it till the exact problem found T_T
Magicmarker
15
Is your clutch fully disengaging? Maybe your synchro's are screwed in your gearbox. What car are you driving?
Norns
497
what is synchro actually ?? im driving satria 1.3 1999
fully disengage ? when i driving fast and i press clutch, it hardly move the stick to 2nd or 1st gear ..... unless my car is very very very slow like almost stop ....
i really dunno wad the exact prob ... the mech wan me change clutch but he himself not sure wad prob ... if change clutch not solve then hav to waste again .... T___T
its very hard to drive in this condition .....
And issit in this condition my car eat a lot petrol ?? yesterdya nite until today my petrol finish 1 block ... damn !
@zri
1,357
i also facing exatcly d same prob wit my waja.. aready change d oil n add volk racing oil treatment summore.. haihh.. izzit my clutch dah nak habis.. sumbdy help plz???
renxun
1,138
37
1,648
ur clutch pls adjust it to higher... ther is a cable in front.. if still cant , do change to a better oil.... penzoil will do good.... if want better go for Q8....if after change oil still cannot high possibility ur clutch says bye bye to u... anyway... check it one by one by sequence as mentioned above...hope that helps..
Norns
497
so, issit clutch or synchro problem ? X....X
if clutch the person say need rm300+ ... if synchro need how much oh ??
i wan to identify which part is problem onli change the certain part ....
and what do we explain synchro ? some mech seem not sure bout that ler ....
i need fix it cos really really inconvenient for my car ... T_T
nitrus
2,895
35
1,648
I tot normally if u're moving, its not advisable to change to gear 1? Mine also when moving time i cant push to gear 1 if not later got "krakk" .. Have to go very slow only can masuk gear 1 from other gears
Norns
497
errr, so issit really normal or got problem with my gear oh ??
cos i really notice this 2 days ago onli ....
If my car moving slow also hardly move ... like got thing block the way ... my car must be super super slow until amost stop onli can move to gear 1 ...
nitrus
2,895
35
1,648
erm.. may i ask how long have u been driving Norns ? cause i think its normal .. lolzz.. i might be wrong?
yewjunyan
108
my car also had dis kind of problem before..my foreman said is my sync. kong d....cost me rm75 for one gear...add up it cost me around 300...
davidv00
952
7
Selangor
yeah for MT cars, sync damage is normal. to avoid such thing happening again, clutch in fully whenever engage any gear
Norns
497
how do we call 'sync' to mechanic ??
cz i notice most mechanic blur when i mention sync to them ? any chinese word to tell them ?
RedD
644
anywhere..
sync. = gigi = "nga" :_:
here's a pic of the map to TiTAN's shop.
but here's a instruction list anyways.
you're on the MRR2 and coming from Jalan Ampang/ Ampang Point / Zoo towards Cheras..
go straight, about 2km after Ampang Point, there should be a turn-off on the left,
Pandan Indah on the flyover bridge.
you should be able to see this 3 white condo's
DONT TAKE THAT TURNOFF!!
(actually can la, but kinda jam..)
take the 2nd Pandan Indah turn off. (right after/next to...
