engine jerking... b16a
shah5755
355
31
Pj....kch
need some help here bro....my ride keeps on jerking mostly during low rpm around 1k-2500 rpm....if use low gear not so bad jerking but if u use the high gear xpesially 4th gear will feel more jerk...
when check spark plug, 1st and 3rd plug got black mark and a bit wet......after clean/change plug ok but only for 1-2 weeks (jerk again).....ask fren they said need to top overhaul.......is it:smokin:
arrowhead
4,621
152
5,163
Damansara/PJ
engine jerking could be caused by several things bro... i would firstly check my ecu/chip. try to replace with a friend/foremen and test.
if still got, check the following:
distributor
plug cables
injectors
spark plugs (but u said u have checked)
thats all i can remember for now.
cheers. keep us updated
good luck
D-IV
262
The plug is wet due to engine oil or due to fuel.. i'm sure you can tell the difference. If oil, then there's some leakage and if its fuel, then its overfuelling.
Don't tell me you floor the pedal at 1.5-2k rpm at 4th gear. Thats crazy hehehe.
AD_EG
6,328
231
Ipoh
bro it could be your plug seals have gone bad.
if its oil,then you might have problems with your seals
if its fuel,its either over fueling or then your spark has got issues,distributor got problems....
is your car stock? any VAFC? piggyback ? fuel regulator ? what is your car setup?
shah5755
355
31
Pj....kch
my car still std b16a oni changed exhaust to straight flow.....from my view it seems like wet coz of fuel.....after clean plug no more jerking but after use for 1-2 weeks start again but not so serious....high speed ok no prob hehe
---------- Post added at 10:47 PM ---------- 6 hour anti-bump limit - Previous post was at 10:37 PM ----------
my car still std b16a,exhaust oni change to straight flow....seems like wet due to fuel bro,will try to send my car for proper inspection......btw its only jerk during low rpm,but when high rpm no jerk.....no vafc,piggyback etc hehe std mendet....
AD_EG
6,328
231
Ipoh
hmmm ok...then it might be a spark issue....check ur cables and your distributor....try to ask your mech to swap your distributor if he got an y spare lying around and see if it solves the issue....
E-Tech
1,115
256
3,183
Johor
Bro
Not everything is cause by ecu BUT
I have repair ecu that the customer
complained just like u... STD but have
over fueling....
So pls have a looking on ur ecu per my
posting on Ecu Warning....
Tq
Aug 15, 2010
perak
im facing the same prob here.... it happen bila2 dia suka. Last time i thought it was my gearbox. Yesss tukar the gearbox last year. It cost me 2k. But still the same prob happen. My foreman also pening kepala (maybe he's not very familiar with jazz auto). Then my wife notice something. The foreman use this oil that obviously stated "DO NOT USE ON AUTOMATIC TRANSMISSION". When i asked him, he said "ok... no problem punya. Boleh pakai..." So pros, what do u think? I dun want to tukar my gearbox again. Raya is coming... You know what i mean? hahaha thx in advance. :hmmmm:
arrowhead
4,621
152
5,163
Damansara/PJ
well, describe ur jerking... it could be due to the above mentioned... gearbox wise, im not too sure...
Hi Guys,
I have one question that I would like all Sifus to give their valuable inputs. I currently have this problem which I don't have a clue on what the issue is.
Here it goes....
1) What should be the voltage reading at idling?
2) What should be the voltage reading when you switch on your air-con + head lamps?
3) Will the voltage drop when the air compressor kicks in?
My voltage is ~12+ v before I start my engine. After I start my engine, the voltage will increase to ~13 plus...
