Ef3 on B16A
anfernee
246
Originally posted by hopesfall+Mar 12 2005, 01:56 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (hopesfall @ Mar 12 2005, 01:56 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-antonio@Mar 11 2005, 16:37
-all big V's g/b from EF,EG,DA are same or not???
no big V from EF :(
EF & DA..cable clutch
EG..hidro clutch [/b][/quote]
EF got big V also wor.. the EF8 last batch some of it is big V engine.. but wiring still small V and everything else also small V one... only engine is big V.. but quite hard to find... see if you're lucky :P
antonio
Old Member
582
no big V from EF :(
owh ok...one is pump wan is cable...
but the question is....is the gearbox design the same fo ef,eg,da???
bocz the problem now is driveshaft crab....not linkage ker,vtec kecik besar ke...i mean the design....bentuk gearbox itu laaaaa...........
:lol:
soulfly
678
Miri
fakhrain.blogdrive.com
gearbox is not the same eventhough it fits
Y1, S1, J1 and YS1 are gearbox for EF and DA vtecs. DA big vtec have the same wiring with EF (OBD-0), less hassle when doing conversion.
rojak wiring (big vtec EG) conversion is a hassle because it's OBD-I .... gearbox using hydraulic pump summore. if u use big vtec EG, need to have the complete wiring. the choice is whether to use hydraulic pump type or cable clutch type gearbox. if use hydraulic, lotsa thing need to be modified. if use small vtec, wiring also need modified if not mistaken. arghhh confuse confuse.....
better get big vtec DA instead. cheaper than EG.
TODA6866
336
DA big vtec halfcut is it hard to find?
btw, if so many wiring problems....... IF got the $$$, can we jz buy aftermarket ECU to solve the 'rojak wiring' prob? - coz it gives other benefits as well........
killer_V
610
Selangor
N
erm gear box might not be the same
but some ef sifu tell me that u can take the big V gearbox inner parts
and fit it in your small v gearbox like that can lah...
because one of the ef have done it before and still using it till now.....
i can recommend u some best pomen in town...
but before that where r u from?
kl or outside kl?
taknabe
39
bentuk gearbox tak same tapi isi perut boleh rojak. Macam kete killer_V hahahaha...
kalau driveshaf ko dah kong g beli je kat kedai potong je. Kepala driveshaf luar Vtec semua sama Si, CRV punya pun leh pakai, yg lain cuma batang dia EG,EF,DA, batang tak sama panjang. Blah dalam pulak LSD punya tak sama ngan yg tak de LSD. Kalau yg blah dlam kong ko g buat balik kat mechine shop.
Pastu kalu Convert tak kira la dari halfcut EG,EF,DA driveshaf nuckle semua masuk tak yah mod. tp upper urm pakai lama balik.
K..Thank U <_<
kengkawan kalu silap tolong betulkan
TODA6866
336
kl or outside kl?
killer v, wheres the foreman located? having some synchromesh probs with my gearbox........"kraaakng" sound when change gear from 2-3 at high revs
i hope i can get it done safely under good hands........n not too expensive of coz :ph34r:
syiokGILER
652
if yu got the whole half cut, no need to pening laa .. everything is there .. :P :P
soulfly
678
Miri
K..Thank U <_<
kalau pakai knuckle DA tak jadi tinggi ke? coz i read somewhere it's possible to fit, but the height is slightly taller, but no big deal.
Today morning at 6am my friends proton wira got smash by 6 malay guy's on motor bike . they got away with his defi meters ( boost & egt ) and they wanted to steal his intercooler too by pulling the bumper out , but failed , cause his neighbor shouted and gave them a chase by driving till kayu ara but lost them .
They smash the car and the straight away pop to hood to disconnect the battery to kill the alarm .
By the way his other neighbour new CRV audio also got stolen .
