- Dec 10, 2008
- 195
- 75
- 1,528
I just put 2farad caps to the battery terminals and be done with it in my car. Easier and neater. I'm sure 2farad should be huge enough to smoothen it out. I don't have ICE in the car just stock system.
For simple car sensor which calculated the fuel consumption are the MAF/MAP sensor(5v which use the 5v supply from ECU) & the O2 sensor( which the signal(mv for narrowband sensor or ma for wideband sensor) generated from the heat of exhaust manifold ). And I had try to reset the MAP sensor before, but,O2 sensor do the final calculation of how much fuel to put.Bro Kenchoo, does the gains actually come from a more stable supply to the ECU and thus better and more stable sensor reading? Signal to noise ratio. Hence more accurate and precise readings? Have you tried a simple cap circuit with filter directly at ECU and sensors that requires a voltage supply? Is it got to do with more stable supply for spark plug firing? The car manufacturers must have taken into account of this stuff unless car has aged or had been modded.
Still can't buy in where the gains actually come from a more stable supply.
Make sure your cap can stand the heat in engine chamber. And make sure you fuse it. Insulated the capacitor with heat resistant material example superlon. The heat were shortage the life of capacitor.I just put 2farad caps to the battery terminals and be done with it in my car. Easier and neater. I'm sure 2farad should be huge enough to smoothen it out. I don't have ICE in the car just stock system.
cheap because the specs different.related to ESR, resistance & temperature also working hrs. i like to purchase electronic component either for my repairing work or DIY from RS component or Element 14 (formerly Farnell). Sometime the offer the quality product with reasonable price.how many volt? y so xpensive?
i'm interested if the price is lower...
4700uf with 16volt i can get rm1.2 only each.
Try this connection: VS +ve to battery +ve while VS -ve to chasis ground.thats how i connect it.i made my vs with 4 6800uf 25v caps which makes 27,200uf but didn't find any difference aftr connecting to d car could anyone hlp me in this so dat i can make a good vs.
