TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Much neat now...nice....I'm very fond of neat DIY job..It makes those half pass six acc shop guys look like newbie when they see our work...
shiroitenshi
3,676
170
ohms law. Better use the lm7805 linear regulator. just like the lm7809 suggested in smarttag thread.
Sent from my GT-I9100G using Tapatalk 2
shiroitenshi
3,676
170
i just found out about them in the smartag thread.. i bought them and tried.. they really work! much better than using resistors because can stick a heatsink on them...
goohtj
57
12
5,008
Bro, lm7805 is 5v, how you connect? 2 x leds in serie or 1 x led + resistor per set?
goohtj
57
12
5,008
use a lm7809 to produce 9v n connect 3 x 3v leds in series per bank.
led voltage = 3v so 3 x 3led = 9v so no resistor required.
say 12 leds required for your brake light.
you need 4 banks. each bank draws ~25ma current = 100ma.
lm7809 is 1,000ma ~1,500ma loading. or can easily connect up to 40 banks or 120 leds
input voltage = 11v ~ 35v, power consumption = 2watts (14v x 100ma + some powerloss)
advantage of this DIY.
Cheap (RM3) only.
same led brightness when car is started (14v) or not (12v).
option 2. simpless DIY.
connect 5 leds in series per bank. 5 x 3v led= 15v no resistor required.
brightness is lower.
stupidcar
5,000 RPM
5,567
850
Cheap (RM3) only.
bro, i am asking the smarttag one.
Cheap (RM3) only.
Did not know you sifu in this....:driver:
goohtj
57
12
5,008
Bro, me only major in Electronic n Computer..
Btw, where 2 source for good super bright led? tried pasar rd - not ideal.
stupidcar
5,000 RPM
5,567
850
Bro, eBay. It is cheap. So far so good.
Just be careful before u chose the buyer, see if their ratings are better than 99.8% or not.
If it's less than that, then see the past 6 months, how many complains they got.
levin818
1,260
321
3,183
Shah Alam
It is not a good idea to drive the LED using this method. A proper way should be controlling the current but not the voltage. Reason why is because LED has a very steep V-I curve. A slight changes in voltages will cause a huge changes in current. If the LED has a low side in forward voltage due to manufacturing batch, then it may end up blowing these LED in a short period of time.
Would like 2 know if its ok 2 put in tufoil in a Vtec engine like the B16A??
My brother is usin it in his Gti n the found the engine to be running smoother but the dipstick got some sort of stain..... like became foggy/unpolished like!! Can explain wat happened ah?/ Issit normal??
Thanx 4 takin ur time 2 read.....
