DC5 Technical Problems/Issues
gixxer8500
Aug 31, 2010
10
503
Melaka
DC5R FL problem....
hi guys, i just kena a problem with my steering today; when i turn the steering (doing parking/very low speed/idle) there is a very loud knocking sound "tock" coming from my front wheel. it only knocks for 1 time - after that no more until the next few kilometres of driving and it happens again. anybody knows what this is ? sound is bloody irritating... helppp...
kc173
Feb 27, 2011
9
Toda A3 cam :
Hi sifu~i have problem with de tuning.the tuner said cant set de 50 degree cam.the rest ok.anyone know how much de tappet clearance?thnx
kby*88*
26
Ptrajaya/SP
my car/engine will vibrate everytime the tacho reach 5k rpm. this happen at every gear. but above 5k, no vibration. any idea guys what is the root cause?
jzafddc5
Jun 21, 2010
25
5
503
DC5R FL problem....
Sounds to me you have a lower arm bushing problem. Check whether there is a crack or bushings worn off. Replace the bushings would solve your problem..:)
---------- Post added at 12:32 PM ---------- 6 hour anti-bump limit - Previous post was at 12:27 PM ----------
Maybe you can check your engine mounting. Especially on the drivers side (located behind the power steering fluid container). Check for cracks, worn down. DC5r are always known to have weak engine mountings.. aduhh..
dvino
92
10
1,508
hi bro's,
actually aku pun kena bende tu tapi bila lalu atas hump.
any good contact mana nak dapat lower arm bush? the one i know is Hokomoto la.
M1CH@3L
Jan 20, 2011
9
Sarawak
Hello sifu... Any idea on a FD2r push start button set fix into DC5R? give me some information how to fix it on my pls... thanks.... cover n start button only...
