Originally posted by reubenlee+Feb 25 2005, 01:41 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (reubenlee @ Feb 25 2005, 01:41 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-crazykid@Feb 25 2005, 00:23
i only change the piston when i add turbo right? (Reading ^^) where can i get b6 or b8 and WTH?!! :huh: i still blur with all the stuff LOL....i think my engin is detomaso tho.4 more days and ill be getting my car back... :D
since you are using automatic you dun have much problem converting turbo,you dun have to worry about the gear box problem that manual faced when add on.
the pistons are optional,if you want high boost then you have to change.
block also optional because it depends on your boost level..
if you want to have extra acceleration power by adding on turbo:
you need to get
gsr injectors
small turbine like the td02 and l200s intercoller would be essential
custom turbo manifold
adjustable fuel regulator
safc2 at least
throttle sensor to get perfect reading
boost controller(manual or the apexi avcr then you dun have to get the safc2)
b6 and b8 comes from mazda and ford [/b][/quote]
Issnt manual better at turbo than auto? :blink: and what manual face?
how do trottle sensor work?
b6,b8 compatible with detomaso meh? its like for mazda and ford LOL... :blink:
The original HD-E DeTomaso engine is good enough in my opinion. The engine loves to rev and most importantly, it is very reliable and the halfcut is quite cheap.. I'm driving an Espri converted to DeTomaso auto engine (registered with JPJ as this conversion is done in 2002 ). I've never had any major problem with this engine and it has serves me well.. If I am not mistaken, the biggest different between a Deto and the Accent engine is in its head and manifold. DeTomaso used a "hotter" camshaft and a better designed exhaust manifold to increase the original Ascend engine from 100hp to 125hp.. I'm not sure about other tweaks done to the engine, perhaps a higher compression piston?
hehe yeah i know....thats why i love this car,eventhough its an auto but it can rev rev and rev! :D i can get the power when i want it and i can save petrol when i`m not in a hurry.
