Quality or precision parts are good for the timing/clock circuitry. Try using 1% resistors (metal film) for the clock circuit, No problem using the 1/8 watt. Refer to your circuit diagram to determine which are the clock circuit.
Those electrolytics caps are prone to acid leak when aging but tantalum does not. If it fails, than electrolytics will damaged your pcb and your MS are doomed.... If tantalum fails, than you only have a malfunction unit which can be fixed. No problem if you can change all those electrolytics every year.
Those parts that I recommended changes are for higer current transient which will further lenghtened your electronic project life service.
MAX232 and ST232 have different characteristics which require mods to the components. If you use MAX232 than you have to use 1uF 50v capacitors around it instead of 0.1uF. But it's easy just to change the chip if they have in stock.
