~cefiro A31 owners forum~
space_cowboy
713
a..aa..aapolloo
uik...
why selling it off...the heat is around man....
btw, where all the mangkuk hayun arr....
cheers'
gwsallen
314
Originally posted by space_cowboy@Mar 3 2005, 22:55
uik...
cheers'
RB's too powerful.... kecut la... play kelisa better :D
devious17
1,664
586
Kay Ell
One mangkuk hayun reporting in .......amacam senduk? ada baik? hahahahhaa
topui11
1,248
muakakaka.. mangkuk ayun devious17... hahahhaa
weh.. how how? got jalan2 or not? hehehe...
anyway, been really bz ler nowadays. hailat ler... haih...
devious17
1,664
586
Kay Ell
jalan2? freaking slipped on the ice 3rd time yesterday! record temp yesterday -20'c !
space_cowboy
713
a..aa..aapolloo
hello mangkuk hayun #2...
mangkuk senduk #1 here...its been a while ur in here lah, where have u been...?Jalan2 cari makan or cari more mangkuk man....
how have u been lah.....
topui - ur hali cabut already arr...?how could that been...?tell me more....
cheers'
LyzardLaki
463
10
kl
kekekeke...all mangkuk
space_cowboy
713
a..aa..aapolloo
kekekeke...
cicak terperangkap in all the periuk and mangkuk and senduks till masuk longkang....
ekekekekeke...
devious17
1,664
586
Kay Ell
hhahahahhhahah......sup cicak anyone? hahahha
Me in EU at present, to engrosed with work. Open concept working environment so less chance to do my own stuff except after work.
bvalve
2,330
16
群&#39340
good lah,can drift mah...kekeke :lol: :P
black widow
90
hai guys can some one help me...
actually i bought my cefiro two week ago, and one of my friend advice me to change all the belt and also some other important parts. since then my car was run very smoothly. just two days ago it start white smoke ,when i check in workshop they told me better to change engine bcoz the cost of overhoul is equel to one half cut car, but now the problem is just two week ago i change my all belt including timing belt. wat should i do ..... it s better to repair it or change the engine . plzzzzzzzzzzzzzzzzz give me suggestion.
a31gtst
507
You mentioned that you changed all belts including the timing belt.
I assume that you would have changed the water pump. If yes it could be a faulty or leaking water pump.
White smoke is usually water burning, blue and black smoke is oil burning. So since the most recent change was the belts and assuming you did change the water pump, its best to check it out. Go back to the mechanic who did the change to confirm it...check your radiator and reservoir water level make sure it doesnt go dry and overheat the engine.
And yes it is probably more worth it to get a transplant done then an overhaul.
Just the r32 engine alone will cost around 1k +/-
r32 halfcut probably around 2.5k
Engine overhaul can cost anywhere between 800 to 1k....
cheers ;)
devious17
1,664
586
Kay Ell
water burning? if the water gets into your combustion you wouldn't have any smoke of any kind.
White/blue is burning lub
grey/back too rich mixture
water? change engine.
The Marketplace Top Posts
Hi to all of ZTH'ers.
In this thread I gonna show I've replace brake master pump with the repair kit.
I've perform this operation on my wife myvi 1.3 AT with ABS.
The symptom is the brake pedal will go straight away to floor when press the pedal while driving. Everytime has to pump it 2-3 times until can feel the brake operate.
Tools needed
1- C clip plier
2- 12 mm spanner
3- 10 mm spanner
4- 8 mm spnanner
5- tubing
6- bottle
7- 10 mm open end hexagon spanner
1- Contain of...
