can b18cr head intall in b16a block ??
harpoon
607
7
shah alam n amp
bro,
that rojak thing can aways be done.
ppl even put b16a or b18c head mated to b20 bottom,
b16a has a shorter stroke compared to b18c.
b16a bore n stroke: 81 X 77.4 mm
b18c : 81 X 87.2 mm
so the piston size is the same, only a lil diff on conrod length.
block height differ by 7mm
there's a page at honda-tech that gives all info bout dimensions
of both engines, from there you can compare n figure out what u
need to do
or else u can check it out at
http://www.import-dr.com/table1.html
harpoon
607
7
shah alam n amp
little mistake there, b16a n b16b same b&s, my typo error
danieL
686
xerofighter said:
b16b has higher lift cams then b18cr on the intake side. exhaust i think its the same.
you are right, but its only 2 degrees lerr, put one adjustable cam pulley kau tim...........
danieL
686
eater_eg6 said:
any diffrent wif the b16b head n b18cr head ??? can rojak wif the b16a ??? gona moddify anything ??? thanx.. :)
you can put with a b16a block, no problem..........
but since u already have such a nice head, put b20 block lah....... !! heehhe
danieL
686
oops my mistake then..
what i am trying to say is that a lot of ppl think the b16b cams is better than b18cr cams......true to a certain extent lah, 2 degrees
but u can push the b18cr cams to make it as "good" as the b16b....
aramis
678
Cyberjaya/KL/PJ
www.scuba2u.com
I thought 3 degrees? :p
danieL
686
not 2 meh....
but u are the sifu here.........you should know better right? hehehe
danieL
686
aramis sifu has spoken....
The Marketplace Top Posts
Black is one of the most difficult to deal with colour, difficult to maintain, to upkeep from scratches and also prone to lots of visible dirt and grime. We have with us today a Black Mercedes A250 Sport, one of the most hyped and wanted hot hatch in the market at the moment. We were given this special opportunity to fix up this ride...
