Only sifu aramis can answer this ....hattech-v said:b16b cams better than b18cr? why aaaa?
danieL said:oops my mistake then..
what i am trying to say is that a lot of ppl think the b16b cams is better than b18cr cams......true to a certain extent lah, 2 degrees
but u can push the b18cr cams to make it as "good" as the b16b....
SiGNAL said:b16a also 3 camshaft lobes..
u call it combustion chamber ke bro...? (d explosion happen there after compression cycle)... if i were u... i'll go for b16b head...eater_eg6 said:got clearence between head n block ??? wat mean ??? dun understand lar... do u mean the combusion chamber is bigger for b18cr head ???
agreed... :rolleyes:Xenix said:my advice.. waste no time and money..
B18 or B16.. Type-R or No Type-R doesn't matter..
It still not giving you the best your can get from it..
I am using B18C-5 head.. But P&P by Amoil Motorsport for serious performance. Use any head.. but send it to P&P.. a good P&P head is much more better even compare to Type-R..
Maximize the peformance from the part you got.. No matter is it B16 or B18 head..
