C-GROUND Customized Grounding Solution
kenken
931
Ipoh
can use your product if battery is relocated to the trunk?
Dear bros...
Yesterday I've swapped my rims to waja first edition rims.....after balancing and alignment and also adding a spacer for the rear wheel because it seem the offset is to inside kena absober.....so after that when i drive....nice but once i apply brake...i can feel vibration from the brake......why ar?? is it the rear spacer make it like that ar...previously....using 8holes rims also no problem like that and with spacer at the front summore....sigh....anyone installed waja rims...
