brake problem
quicker
26
1,503
malaysia
i hv just repaired by braking system, after the repairing I hv to step deeper on the paddle only i can feel the respone of the brake. Can we lower the paddle so that no need to step deeper to get the respone of the brake? Can the brake paddle be adjusted to lower level? Anyone face this problem before ?
all your comments are welcomed...
budin99
429
look like the mechanic did your brake service before did not doing the oil bleeding. There are bubble inside your brake line.
sen it back to the mech and ask for the brake oil bleeding. should be ok after dat
shiroitenshi
3,676
170
There's an adjuster nut for lowering the pedal, but you need to make sure that it's not another problem causing it, i.e. faulty pump, brakes not bled properly, etc.
Im driving a 2-door EG with 1.8l Vtec. Im currently searching high and low for a quiet exhaust....besides mugen twin-loop, does anyone have any other recommendation?
Power gain is not important, as long as it is quiet and there is no power loss, I'm happy. :)
