my xperience is otherwise...Friend try add Tufoil engine treatment next time when u change engine oil..the engine will run cooler /quieter/smoother/more powerful and save petrol also retain your engine oil level..interested let me know if ur place don't have any seller. and the Tufoil mix well with mineral/semi/fully synthetic oil without clog ur oil filter.this engine treatment really good stuff
my engine oil will kurang also over some times....i put in torco mpz friction reducer..it seems better nowcan i know, the engine oil will less after hi revving or else is a normal case or something wrong with my BT 5speed? 1st using honda 10~30, after that try petronas semi 10~40 also same issue. now using LEXUS brand fully syn 5~40 will dry soon
i know that BT is a high temp engine..mayb the engine oil will burn and disapear or be 'tersejat' in the engine like bro napxx said. somemore i can smell like burned engine oil after down the window. same case when last time drive kancil 850.
for my experience, during my 1st transplant 4age 20v, the pomen full in the oil NAZA 10/40w, oil level slightly reduce by month to month due to have high revive till 7k rpm. but now changes to eneos type not more oil leaking level even though always high revive till 7k rpm. :wavey:my engine oil will kurang also over some times....i put in torco mpz friction reducer..it seems better now
im running 5w40 + torco mpz in my GTR....i try not to use xW50 or xW60 oil grade...not so prefer
thanks 4 sharing..but urs is GTR woa...mine is only seg111 buruk woa..keh3..my engine oil will kurang also over some times....i put in torco mpz friction reducer..it seems better now
try checking your campulley oil seals, your VVT o ring, your oil pressure sensor, oil pan and your distributor.bro nappx, i think no more any oil leak at the front view.. at the behind still not trbleshoot. will do it someday. my opinion is there possible somethings wrong with my exhaust system like gasket bocor or something would cause the engine oil disapear? (in progress changing OEM BT exhaust system: oem extractor + catalytic converter with sensor + full set oem piping, bullet and muffler) if same case come out, still have to trbleshoot again.. then sakit kepala again kah3...
---------- Post added at 04:21 PM ---------- 6 hour anti-bump limit - Previous post was at 04:13 PM ----------
is it GTR engine also have a high temp like BT engine?
yaya..thanks for remind me..distributor mayb not..will try check the other 3 parts. sumore mayb flywheel oil seal? there oso got engine oil come out if bocor right?.. if kancil pengsan already lo keh3 have to turun engine wo. lucky me using BT keh3..try checking your campulley oil seals, your VVT o ring, your oil pressure sensor, oil pan and your distributor.
with low temp thermostat and fan setting, normal drive 70-75 degree only..if whack it hard...80-83degree only normally. transmision oil temp also like that.thanks 4 sharing..but urs is GTR woa...mine is only seg111 buruk woa..keh3..
