B16a Engine Simple Modification
shiroitenshi
3,676
170
hattech-v said:
shiro,
cam lift is same, only duration b16b higher than b18c...
1. ITR/CTR (Chilled Cast Cores)
- STOCK 1997-1999 ITR
INTAKE lift - 11.5 mm, duration 240 @1mm
EXHAUST lift - 10.5mm, duration 235 @1mm
- STOCK CTR and 2000-2001 ITR
INTAKE lift - 11.5 mm, duration 243 @1mm
Use the cam dial.. it's 13+ for B16B
At least that's what the measurement is when one of the fellas measured his cam lift while setting up the cams.
shiroitenshi
3,676
170
it's supposed to be the same what... since the guy got 11+mm when measure B18C.
shiroitenshi
3,676
170
hattech-v said:
then 13mm is more than JUN 3 lift wooo... jun only 12.5..
True.. but still those are the numbers I got.... if you got real measurement.. then let me know... Since those numbers are only one time measured only.. the guy sold the engine and car becoz he said B16B power too lousy.. (O_o) now driving EVO 7 with 500+hp edi... (O_o)... scary!
akuma
3,489
152
Kuantan
shiro,
"b16A head with B16B cams have really tight tolerances"---->u sed dis wat?so if a B16A head is similiar w a B16B head,in terms of d height @ least,so shud haf no problem wat?
J101,
yayapapaya..u alwis flen flen...but whn i ask u mau "pengeras"!hahahahha
xxxx,
i din say B16A head exactly d same as B16B ler...but if i'm not wrong,a B16B head is produced frm a stock B16A head,no?
shiroitenshi
3,676
170
akuma said:
shiro,
That's the thing.. if the B16B cams have higher lift.. that means they are closer together at max lift, both with each other during overlap, and closer to the piston face too..
That's why I said.. "B16A head with B16B cams"
Was planning that upgrade.. but B20B more bang for buck.
shiroitenshi
3,676
170
Bang for buck lah akuma!
If got 40K.. I'd do it already lah.. (do everything overseas incl. tuning the K-pro) then send back the complete shebang down to MY.
Problem is too much bang.. and too little bucks on my side... ROFL!
shiroitenshi
3,676
170
Just heard new JPJ rules from friend.... cannot modify mounting.. Ishk! no more K20 legal conversions loh!
ace79
1,082
Aiyak? Are you sure? I hope money still talks over at Puspakom and JPJ...
shiroitenshi
3,676
170
Of course it does.. it just means... more money.. ROFL!
The old Civic 2.0 with the crippled K20 and the later version still can.. it's just the 6th gen and below that have to modify engine mounts...
The Marketplace Top Posts
'(00): Some shots from the recent RCA track day couple of weeks ago, here's a fire breathing S2000 who was putting out great laps driven by Shaun from Ascendant...
