B16a Engine Simple Modification
xxxx
1,816
hehe.....akuma.....b16a n b16b almost the same.....but there's some small details that r not the same....
those ppl who doesn't know will say same same.....but in fact.....they need to do more research......no offence k?
apexivafc04
91
Almost dont know what to say, anyway thanks alot all sifus!!
Yes, i heard that aerospeed adj cam pulley are inaccurate. Is using the ctr cams make ur car idle rough? What about the ignition timing setting? Stock is 16 degree.
When i first purchase the halfcut there is no rev limit. That mean there is no fuel cut, with the ctr cam and valve spring what rpm limit should i rev to before gear shifting?
Can i change the crankpulley to more lighter one.
Thanks and cheers!:regular_smile:
c00lric
658
U wont hav the rough idle by using ctr cams. They r just higher profile compare to b16a cams. U can change to lighten crankpulley. No harms done. About the max rev, may da otais n sifus can help ya on this. Happy modding.
J101
1,304
malaysia
theres no rough idle on CTR cams. leave the ignition at base setup as you are not dialling the intake cams.
to be safe, dun happily rev your car to extreme even there is no rev,fuel,speed cut. since its from the halfcut, god knows what happens in between japan and malaysia unless u wanna rebuild entirely.
if you have a balanced engine after a full rebuild, the lighten crank pulley would serve the purpose. in the mean time, just save the money.
cheers
The Marketplace Top Posts
Hey, my dad's Vios(dugong) idling too low and sometimes can lead to engine stalling.
He went to Toyota service centre and this is what the SA told him.
"Vios is meant to be used with RON97 petrol, RON95 use d will leave carbon, that's why the ECU adjust the timing become like that. Cannot adjust timing manually also, so you need to bring your car in for diagnostics"
WTF? Vios is meant to be used with RON97?
What bullshit is this guy saying?
What to do now? Really can't manually...
