lithium2 said:Just found out my car is not using P30 ECU. It was a chipped SOHC Vtec's ECU. Will this cause problem to my car?
What difference can I get if I use back original P30 ECU?
lithium2 said:Oh...... so there is no problem with this P08 board? By the way, what is the knock sensor board for? To activate airbag??
Someone told me if using P08 board, fuel consumption is higher. Is this true?
the knock sensor board is like for automatic knocking correction. to describe it in details i dun know.lithium2 said:Oh...... so there is no problem with this P08 board? By the way, what is the knock sensor board for? To activate airbag??
that one i thing not ur ecu problem. but the knock sensor (attached to block) itself kong edi.jingut_04 said:sorry to ask,how look the knock sensor board?i'm using SOHC Vtec(local model)is it mean my ECU have no knock sensor board(even last time facing knock sensor error) & my mechanic ask to change.
p/s:mie,kalo ada gambaq,kasi post tgk
RM500 for stock ecu.chris2000 said:hattech-v
How much you selling the JDM P30 ecu? it comes with knock board right?
