All type of sound from my car... help !
  • Jan 2021 Updates: 3 Letter Search Activated, try it now! | Homepage, Forums, Marketplace pages refreshed! | Top Start Thread Button added | Site notification emails are now more secure!
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
Jack it up and hit the tires with base of your fist, it will give some noises if the caliper pins already worn out. But the noises from that is more like lite rattling sound. Your knocking noise can also come from worn antiroll bar bushings so the ARB might have up/down movement and touches some of other parts or lower arms. That was the case for my Swift.
I just jacked the vehicle and try to shake/knock/punch and nothing gives or produce sound. I removed the tire and try shaking the brake using hand and it moves a tiny bit. Can feel its metal to metal contact so i removed the caliper pin and cleaned them;
I cant feel any wear with my fingers. The pin comes with that flat surface and its not cause by wear and tear. There is some metal contact sign but no wear can be felt using finger. When i put back the caliper in the slot and try to shake it it moves in all direction for the bottom pin but the top pin only moves very slightly.
So are the pins worn out?
If yes should i go for original pin or aftermarket with silicone ring?
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
After lubricating and putting back, does it still make a sound?
Forgot to mentioned, that pin was coated with grease when i remove them. There was free play when it was still coated with grease. The pic is taken after i cleaned them to show the surface better.
I havent lubricate it back as i dont have high temp grease with me.
Boooooossst
Boooooossst
15,112
6,338
Dude, if you didn't lube it back, it'll cause more noise. It's supposed to move in and out a bit for single piston calipers like yours.
Is that a Myvi caliper pin? The silicon one does help but even that silicon one is wear and tear. Faster lube it up, it's not healthy for metal to metal rubbing without grease
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
I havent put it back.
Thats the original pin since 2008.
i know its suppose to move in and out but it can move up and down left and right. Is the other movement instead of in and out are normal or should i replace?
Boooooossst
Boooooossst
15,112
6,338
Replace it if it's moving that much. But you need to test it with grease, not greaseless leh.. The problem with the silicon o-ring type is you grease need to do it nicely. Can't put too much because it'll compress the grease making the caliper hard to move and then braking failure
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
Just bought this replacement pin with silicon. Ori replacement only left 1pc.
Already install right side after smeared with bearing grease, play with the pin by pushing it in and out then smear again.
RM75 for a set. After dinner will install left side and hope no more sound. If still got then i am lost as already check the arb bush and lower arm are all in good shape. no loose bolt or freeplay.
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
Shit....noise still there despite the improve pedal feel.
When i drive just now i had the window down and notice the sound when i turn the steering at stationary..Its the damn steering rack bush.
  • Like
Reactions: leinnz and Izso
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
so culprit is steering rack
The steering rack bush to be exact.
Its not worn out to the point the rack is moving freely. Its in a way still holding the rack firmly until a point it gives by making the rack moves suddenly in few short amd sharp movement.
kinda hard to replace esp the passenger side due to P1 bad design of having the aircond drain pipe above the nut of the bracket. Its rusted almost beyond recognition.
parakey
parakey
1,333
209
663
Is the BLM's rack bush similar to the one on the Preve? I hear FB group people frequently complaining about it
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
That one i dunno. The ori one i just bought only written BLM on the box. Will try to remove the rusted nut this weekend.
Last time with waja i encounter short lifespan of steering bush. A tire shop notice my loose bush while doing allignment and told me to put a short timing belt or aux belt cut to make it tighter and last longer. I did that and it works. I used abt 1 inch a piece at both side.
parakey
parakey
1,333
209
663
MY tyreman did the same for the Wira's lower arm bush
gunnerzz
gunnerzz
Jul 3, 2014
1,977
647
713
35
Melaka
Thats new to me. Normally new lower arm with new bush are a bit harder to fit in esp the end with that square bush end thus it fits in a snug manner. BTW my bro mentioned that the correct way to install lower arm is to fully tighten all bolt/nut when the car is at its resting position. This is near impossible to do at home unless we have a hoist. Its done to ensure normal lifespan.
parakey
parakey
1,333
209
663
Was some years ago. While doing alignment, he noticed the bush was worn. He took a some rubber tubing and clamped it together with the bush. I left it like that for years.Kinda silly since those bushes dont cost much.
I read something like that before but have yet to see any mechanic do it. I think this is only something you can do if you have one of those lifts that raise the car with the tyres resting on it. Tyreman's alignment lift or the tunnel they dig in the ground
