hey guys, workshop still cannot figure out what is with all the sound....
just want to ask if i were to go for engine overhaul, how much would it cost me?
also, any recommended workshop? klang valley that is
Get 2nd opinion from another workshop, before doing overhaul
iameternal
67
6
40
I can only think of the 1.8 campro stroker kit when he mentioned abt overhaul. That will be worth the time stripping down the engine.
i just want the engine to run smoothly..no intention to upgrade..ha
1.8 is legal might as well swap engine, stroke if possible go 2.0L......hhahahhahhaha
ixeo
4,788
3,080
KL, Malaysia
I thought a lightened crank pulley makes the engine more eager to rev. At least, that's my butt dyno feel when I replaced.
I didnt re-balance the crankshaft.Have engine vibration at idle and few years down the road despite minimal usage, has had to replace ac compressor, alternator. God knows what else is coming soon.
Let experts explain
https://machv.com/pages/tip-11-crank-pulleys
Under drive pulley for a supercharged car I understand. Lightened pulley for NA is pointless for street driving. In-line 4 engines aren’t smooth, I believe the harmonic dampeners do something else manufacturers won’t include it.
ixeo
4,788
3,080
KL, Malaysia
This is the best advice. I got a good mechanic out in the woods in Sungai Buloh if you want.
But he can’t do wiring and electrical — basic only. He’s a mechanic.
Most mechanic don't do wiring, simple one then yes. Major wiring problem always sent to wire man......lol
Mitevo7
1,456
179
Stock OEM.
Trust me.
Why?
I changed to aftermarket one after all the hype. Then I changed back. true story.
Agreed, i am one of those guys who've changed back to stock after 2-3 months on lighten crank pulley, endless problem !
Guys,
allow me to ride on this thread as i am having this problem with my blm.
Recently i hear 'kluk2' sound on my blm. It happen during initial movement when load is transferred to the back. Its very faint that the radio needs to be switched off before the sound can be heard. Its like a metal to metal sound. A quick inspection reveal that the 2 bottom engine mounting is torn thus i replaced all for last sunday.
Car felt like new but the noise is still there and can hear more clearly as the new mounting seems to lower noise coming from the engine. Lower arm is new (less than 1 yr and its ori Proton), no significant free play on tie rod and absorber link to arb. I am starting to think its the caliper pin. How do i check the pin?
Guys,
Jack it up and hit the tires with base of your fist, it will give some noises if the caliper pins already worn out. But the noises from that is more like lite rattling sound. Your knocking noise can also come from worn antiroll bar bushings so the ARB might have up/down movement and touches some of other parts or lower arms. That was the case for my Swift.
I just jacked the vehicle and try to shake/knock/punch and nothing gives or produce sound. I removed the tire and try shaking the brake using hand and it moves a tiny bit. Can feel its metal to metal contact so i removed the caliper pin and cleaned them;
I cant feel any wear with my fingers. The pin comes with that flat surface and its not cause by wear and tear. There is some metal contact sign but no wear can be felt using finger. When i put back the caliper in the slot and try to shake it it moves in all direction for the bottom pin but the top pin only moves very slightly.
So are the pins worn out?
If yes should i go for original pin or aftermarket with silicone ring?
After lubricating and putting back, does it still make a sound?
Forgot to mentioned, that pin was coated with grease when i remove them. There was free play when it was still coated with grease. The pic is taken after i cleaned them to show the surface better.
I havent lubricate it back as i dont have high temp grease with me.
Dude, if you didn't lube it back, it'll cause more noise. It's supposed to move in and out a bit for single piston calipers like yours.
Is that a Myvi caliper pin? The silicon one does help but even that silicon one is wear and tear. Faster lube it up, it's not healthy for metal to metal rubbing without grease
I havent put it back.
Thats the original pin since 2008.
i know its suppose to move in and out but it can move up and down left and right. Is the other movement instead of in and out are normal or should i replace?
[Need Advice] Lowering Car Height
Hi guys.
Currently im using GAB sport springs for my car.
Gap between tyre and fender is as follow; Front = 2 fingers, Rear = 3 fingers
I wanna ask, is there any way to lower the REAR gap to match the FRONT? becoz now the car now is slightly 'tonggek'. not really noticable though..
I dont want to cut my springs or 'bakar' and compress the springs, as i heard this will shorten the spring lifespan and its not safe..
If i change my standard...
