Air cond getting hot
kugas
25
1,503
Hello guys....need some input....
I installed front intercooler on my GTT last week....now my air cond getting hot when my car not on the move.....i think maybe new intercooler restrict the aircond fan air flow...any opinion ?
Innocente
254
4
I think the motor in the fan is weak. the inter-cooler just makes it more obvious.
calvintys
130
klang
Check your water temp, if your air cond get hot suddenly, the link to it is mostly the water temp has increase i am sure by the time you realize it, it should be over 100c. You dont wana blow your head. Secondly would be check your radiator water, i think you will need to be refill. Then only check with your fan.
kugas
25
1,503
Hi guys,
thanks for the inputs....i've checked all the control system looks working fine...I found 2 things:
1) I found a plastic bag between radiator and air cond condensor it covered almost 30% of the radiator area - Removed
2) I found ambient air temperature sensor relocated from original location - maybe during intercooler installation.
any opinion guys....
To All Sifu,
I just install arkdesign advance boost controller to my car.Appreciate if all sifu here to explain and teach how to do the setting. A bit confusing on SET and GAIN. Normal boost 1 bar for my car .My car spec is VR4 engine ( rojak ) TD 05 with[FONT=&quot] Tial 40mm wastegate and Tial 50mm blow off.
TQ
[/FONT]
