Any reviews on ATR Sports 2? I am almost coming to my 2nd year on the same ATR Sports 1. I know all the pro and cons of this tyre.
Hoping ATR Sports 2 will improve it further.
it is base on ur tire size lahh bro..like mine 205/40/17 i put 240 kPa/34.5 psi..if i put higher pressure tire confirm will not grip..n if i put less then the tire will makan tepi..so be careful..n the best way is u try to ask the tire shop..n u isi urself the tire because sumtimes their readings not really accuratetrue.. shall I say my front tyres are at 44psi? :D.. the grip and steering gets better with higher psi. Wira is very front heavy..
Wow! 44psi that is pretty high. Not bumpy? Max should be around 38psitrue.. shall I say my front tyres are at 44psi? :D.. the grip and steering gets better with higher psi. Wira is very front heavy..
Yup, my 45 series also 240 to 250kpa....i put 250kPa like a bawse for fuel efficiency.muehahaha
Nop! My 195/55/15 still a little bouncy at low speeds.. like i say soft sidewall. The higher pressure helped a bit..Wow! 44psi that is pretty high. Not bumpy? Max should be around 38psi
---------- Post added at 04:46 PM ---------- 6 hour anti-bump limit - Previous post was at 04:46 PM ----------
The max rating on the sidewall usually is for beading the tyres to the rims and not max pressure for use.Nop! My 195/55/15 still a little bouncy at low speeds.. like i say soft sidewall. The higher pressure helped a bit..
I pump to 44psi as it is max rating stated on sidewall..
WHUT.The max rating on the sidewall usually is for beading the tyres to the rims and not max pressure for use.
These are a few info that I can find....WHUT.
I always pump using the max tyre pressure!
