Achilles ATR Sport
BFX73
116
13
fitted with ATR sport 195/55/15 x4 = rm700
been using it since friday
so far still ok...nothing unusual...going to genting to warm up the tyre...grip(dry) i can say is good...on saturday i spiritedly driving along duke-penchala link-sprint hiway-mahameru-plus hiway to nilai...the feeling is good too and confident driving at 200kmh for a moment...
no track day just yet...will continue to gives review when i get a chance to drive this tyre on track
InitialD
1,299
93
Any reviews on ATR Sports 2? I am almost coming to my 2nd year on the same ATR Sports 1. I know all the pro and cons of this tyre.
Hoping ATR Sports 2 will improve it further.
mofisa
9
1,503
this tyre is AWESOME!!
love it..be it wet or dry. karak genting sempah LPT is not a problem.hehe
Roger89
60
11
508
^ very good on you! I feel the same as well.
One problem I detected after more than 1 year usage is the incredibly soft sidewalls.. due to my front spring I changed to 6k (wira 1.5).. now whenever going over uneven bumpy road the tyre literally bounces like a balloon. So it is bouncy at low speeds. Definitely is the tyre sidewalls becuse when I press the bonnet and let it rebound can see it is the tyre that gets compressed. Anyone having this same problem?
faruck
861
46
selangor
the sidewall of the tyre is lil bit soft..so u must be very careful on the tyre pressure..if not cepat makan tepi..
mofisa
9
1,503
i have heard someone told me before that this ATR is need our special care on the tyre pressure. have to ensure the tyre always has it's optimum pressure.
faruck
861
46
selangor
but the traction for me is the best for budget tyre..the aquaplaning is good also..
faruck
861
46
selangor
true.. shall I say my front tyres are at 44psi? :D.. the grip and steering gets better with higher psi. Wira is very front heavy..
it is base on ur tire size lahh bro..like mine 205/40/17 i put 240 kPa/34.5 psi..if i put higher pressure tire confirm will not grip..n if i put less then the tire will makan tepi..so be careful..n the best way is u try to ask the tire shop..n u isi urself the tire because sumtimes their readings not really accurate
Wow! 44psi that is pretty high. Not bumpy? Max should be around 38psi
---------- Post added at 04:46 PM ---------- 6 hour anti-bump limit - Previous post was at 04:46 PM ----------
i put 250kPa like a bawse for fuel efficiency.muehahaha
Yup, my 45 series also 240 to 250kpa....
Roger89
60
11
508
Nop! My 195/55/15 still a little bouncy at low speeds.. like i say soft sidewall. The higher pressure helped a bit..
I pump to 44psi as it is max rating stated on sidewall..
The max rating on the sidewall usually is for beading the tyres to the rims and not max pressure for use.
WHUT.
I always pump using the max tyre pressure!
:banghead:
These are a few info that I can find....
Maximum pressure is also stated on the tire sidewall. This is different for a tires recommended tire pressure. This number is the maximum cold pressure necessary to carry the maximum load for which the tire is rated.
TIRE MOUNTING
Tire mounting must be performed by specially trained personnel using proper tools and procedures. Failure to follow safe mounting procedures can result in faulty positioning of the tire and cause the assembly to burst with explosive force sufficient to cause serious personal injury and death. Clean rim and lubricate beads with rubber lubricant. Always lock rim on mounting machine or place assembly in safety cage. Use air hose with clip on chuck and extension air gauge. Never exceed maximum recommended PSI to seat beads on rim. Excessive air pressure can damage the tire and cause it to violently blow off the wheel. After mounting, adjust to recommended inflation pressure.
Maximum Air Pressure - "300 kPa [44 psi]"
This indicates the maximum operating inflation pressure of the tire. It does not indicate the manufacturer's recommended inflation pressure, nor does it indicate the proper air pressure based on the vehicle the tire is mounted on. This category is also based on NHTSA standards.
Using the max air pressure, when the tyres get hot when running will make the air pressure go over the max. Probably if want to use max pressure pump up to 40 to 42 to allow for heat expansion
A few days ago we posted what seemed to be the future of Mclaren. And now we’re posting something closer to what the real production version of the Mclaren will look like. Due to go into production in 2010, the new Mclaren will take on the likes of Bugatti and will be a potential Ferrari Enzo and Lamborghini Murcielago replacement. Unlike the original Mclaren F1, the new one seems to be a strict two seater...
