4g9X Gasket for BOT,Turbo and Mivec hybrid 93
wira_tak_laju
4,184
planning on bolting turbo on ur 4g91,92 and 93 without chnging internals..??or mivec with 93 block with mivec pistons??..this gasket is the answer for de-compression purporses to avoid knocking and support higher boost..
1.8mm FULL METAL (MMC JAPAN) gsket on
-1.6 4g92 sohc BOT gives approx 9.8ish comp ratio
-1.5 4g91 and 1.8 dohc BOT gives approx 9.5ish comp ratio
-mivec 4g93 block with mivec hi compress pistons gives comp ratio 11.2ish
-4g93t 1.8 gives 8.01ish comp ratio for higher boost for drag
orale carnals..chale!!
016-2458121 fazlee
akmar ismail
598
bro utk mivec waja ada x? ck4a punya.
How much for 1.8mm
akmar ismail
598
metal ka bro? price ngan delivery skali ke?
x bleh less skit ke?
wira_tak_laju
4,184
Yes my Penang fren..thnx..get another set of 0.4mm la to make 0.8mm or get 0.9mm 3 layer..only 200 nett
Hi all,
Im new to turbo world and need some advice on my new upgrade RVR 4G63 Turbo.
I have complete
1. stainless steel piping.
2. Works Fuel regulator.
3. Turbo timer
4. Turbo meter
5. Pivot speedcut
6. HKS blowoff
I did the dyno with 176HP & Torque 21.49
With the current standard ECU with TD04H, need advice what to install to achieve 300HP?
Current issue I have now are during uphill, there are no power at all unless pedal for more fuel or change L-gear. When I ask around...
