4g9X Gasket for BOT,Turbo and Mivec hybrid 93
wira_tak_laju
4,184
planning on bolting turbo on ur 4g91,92 and 93 without chnging internals..??or mivec with 93 block with mivec pistons??..this gasket is the answer for de-compression purporses to avoid knocking and support higher boost..
1.8mm FULL METAL (MMC JAPAN) gsket on
-1.6 4g92 sohc BOT gives approx 9.8ish comp ratio
-1.5 4g91 and 1.8 dohc BOT gives approx 9.5ish comp ratio
-mivec 4g93 block with mivec hi compress pistons gives comp ratio 11.2ish
-4g93t 1.8 gives 8.01ish comp ratio for higher boost for drag
orale carnals..chale!!
016-2458121 fazlee
akmar ismail
598
bro utk mivec waja ada x? ck4a punya.
How much for 1.8mm
akmar ismail
598
metal ka bro? price ngan delivery skali ke?
x bleh less skit ke?
wira_tak_laju
4,184
Yes my Penang fren..thnx..get another set of 0.4mm la to make 0.8mm or get 0.9mm 3 layer..only 200 nett
It was game time, and only the cream of the crop were back to set aside the men from the boys. Bringing you’re A-game was mandatory, and boy did they bring it. The time to step up and be counted was finally upon them and based on the time sheets, every single driver was up for the count as Zerotohundred.com’s Time to Attack: Sepang, The...
