4g9X Gasket for BOT,Turbo and Mivec hybrid 93
wira_tak_laju
4,184
planning on bolting turbo on ur 4g91,92 and 93 without chnging internals..??or mivec with 93 block with mivec pistons??..this gasket is the answer for de-compression purporses to avoid knocking and support higher boost..
1.8mm FULL METAL (MMC JAPAN) gsket on
-1.6 4g92 sohc BOT gives approx 9.8ish comp ratio
-1.5 4g91 and 1.8 dohc BOT gives approx 9.5ish comp ratio
-mivec 4g93 block with mivec hi compress pistons gives comp ratio 11.2ish
-4g93t 1.8 gives 8.01ish comp ratio for higher boost for drag
orale carnals..chale!!
016-2458121 fazlee
akmar ismail
598
bro utk mivec waja ada x? ck4a punya.
How much for 1.8mm
akmar ismail
598
metal ka bro? price ngan delivery skali ke?
x bleh less skit ke?
wira_tak_laju
4,184
Yes my Penang fren..thnx..get another set of 0.4mm la to make 0.8mm or get 0.9mm 3 layer..only 200 nett
Hi there,
Does anyone know how to do 'Double Signal' that will stay on (Front & Rear) with switches to control on/off. And it will still blinks when u use the signal.
