ftzone,
Thanks for the pointers. As for the "fuel pressure", how to know there is sufficient pressure?
I feel my third-gear a little 'under-powered'. Rev until 5k also not much push. Could it be that my fuel (going into engine) isn't sufficient? I'm still using stock Wira fuel-pump.
I'm not really sure how to treat a turbo-engine. Just a short survey for my reference, on how you guys drive your GSR.
1) Do you double-clutch when changing gear?
For me, I do it for every gear. I heard it can reduce wear-and-tear on the syncromesh. I find that my second and third gears sync-mesh isn't in a good condition, as it isn't smooth when entering those gears.
2) Do you turn-off your aircon when revving >4k?
I do. Might spoil the air-con compressor during high-rev.
3) Do you use engine braking when making sharp corners?
I don't. Don't know how to use the toe-heel technique properly.
4) Do you leave your engine to cool-down before turning it off?
Not really, cause i rarely boost.
