Hmm .. would it not possible to custom a roll cage to be hidden within the ABC pillars?Bro. Izso, Bar in engine probably can hide. Fit Roll cage, you know who get shot first.....hhahhahaha
4G15 Wira not C97 chassis?4G63T transplant in a C91 chassis is just asking for trouble. Accident, cannot claim assuming you survive. That chassis was not designed for that much power either so expect it to crack over time. Nose heavy too.
I've seen a C99 Putra chassis crack with a 4G93 NA modded car. 4G63 in a C91? Good luck seriously.
But since you're gonna go illegal, might as well spot weld the chassis while you're at it.
Just because of the weakness in chassis, the whole engine is wasted... Too bad... I wonder if the owner manage to source original Mitsubishi chassis like those of CA4A Mirage Cyborg or Mirage Asti, will these chassis be tougher than then C99?4G93 NA mods with some cusco bars here and there. This was when UltraRacing was still new in the market. Spot welded chassis, solid mounts and stripped. On wheel it was over 300bhp+ and even with LSD it was twitchy. I never drove it because the owner was relatively short. Had a full bucket with modded brackets to cater for his height. As for the mod list, it was extensive to put it mildly. Without the standalone the idle speed was 1k-2k-1k-2k-1k God knows how he drove it like that for the time without the standalone.
The funniest story about this car was his bumper canards were installed at an overly aggressive angle and during sepang, the front bumper snapped off. The fella claims over "downforce" the front
Anyway in the end car was scrapped I think, or was it sold? The front cross member area had tears (don't know the actual name of the area but it was near there) and everytime the fella revved can physically see that tear flexing. If he did sell the car, I pity the new owner. It would only be a matter of time before the car becomes condemned. Hopefully the new owner was smart enough to demod and use normal mounts. Too much stress to the chassis la I think.
No place to hide....Hmm .. would it not possible to custom a roll cage to be hidden within the ABC pillars?
Referring to the attached picture of Proton Suprima. Note that some bars align to the pillars.No place to hide....
the strongest proton chassis was the one and only version Satria GTi R3 edition...true double spotweld (i think it was more like triple spotweld on some area)If going illegal, why stop and spot weld, add iron bar and strengthen.....lol
---------- Post added at 04:56 PM ---------- 6 hour anti-bump limit - Previous post was at 04:55 PM ----------
The Rally one or street one......Rally sure crack loh.....hhahhahahhah
i use fender bar+4point strut bar....but didnt believe much on the undercarriage bar especially the one hooked to the already sturdy engine subframe....Thanks for sharing.
Still we shouldn't place all the blame on the engine upgrade. With more power available, the desire to speed increases
The driver behind the wheel has to share some of the blame. Chassis damage results from aggressive driving. Stuff like extreme corner Gs or high speeds over undulated surfaces. The chassis is severely flexed. Over time, this flex translates to permanent damage.
yeah, I feel the fender bars are particularly important. Mind sharing what other steps you took to stiffen the car? I recently autofoamed my side sills. Car is so much nicer to ride in now.
I don't mean a full fledged roll cage with tubular bars but perhaps modify a bit using flatter, slimmer tensile ones which can later be hidden with the pillars' plastic covers. Roof has ample space to add tubular ones. It's a bit like reinforcing all those pillars and connecting each to the strengthened roof. Should act similar to a light duty roll cage. Likely won't need to wear a helmet driving this.
He He .. with those bars added, car will be heavier. No more pickup :damnmate:
Edit:
LOL .. don't mind me. After re-reading this post, I feel as though my head got knocked on one of those bars. :stupid:
Probably could if you had the budget. But for such an old car, would the cost be justified?Hmm .. would it not possible to custom a roll cage to be hidden within the ABC pillars?
Erkkkk.... 97? Erm. You're probably right. I just googled and there's no such thing as 91. Hehehe.. Paiseh.4G15 Wira not C97 chassis?
I think will strengthen slightly only.Referring to the attached picture of Proton Suprima. Note that some bars align to the pillars.
Edit:
No lah. Don't intend to get roll cage. Merely postulating a wild theory.Probably could if you had the budget.
Apart from skipping the beam under the front seats and those in the roof, I think all other places progressively foamed the past few months. Originally started as a soundproofing project. Midway got detoured to improving handling. So far, I am satisfied with the overall result.i use fender bar+4point strut bar....but didnt believe much on the undercarriage bar especially the one hooked to the already sturdy engine subframe....
autofoam is good start...u can upgrade using the track package....
Yalor, this is the main reason holding me back from overdoing my car. Car is already 19 years old. Have a Proton Preve for outstation trips. Over the past 2.5 years, the Wira having a manual transmission wasn't utilised much. After getting used to the Preve, each time I drive the Wira I find the road noise/drone intolerable. Which was what led to the soundproofing project. After making the recent changes, it is now a much nicer ride. Now backside itchy already.But for such an old car, would the cost be justified?
Agreed .. but then again even with proper roll cage if the car turns turtle, without 4pt harness seat belt, I think we'll still suffer neck injuries.I think will strengthen slightly only.
Looking at the pic you posted, that even have a center 6 point bar to take direct impact....
C99 if same with Evo 1 then shouldn't have issues ripping at 300bhp? Unless because its FWD so the stress isn't distributed evenly.Probably could if you had the budget. But for such an old car, would the cost be justified?
And stronger than c99? C99 if not mistaken is the same as the original Evo 1 chassis. Ok what. Anyway, I dunno what happened to the car.
That is why need to do complete mod, not half way.....hhahahhahahaAgreed .. but then again even with proper roll cage if the car turns turtle, without 4pt harness seat belt, I think we'll still suffer neck injuries.
Can be too. 4WD splits the power to all wheels. 2WD only front wheel gets all the power....C99 if same with Evo 1 then shouldn't have issues ripping at 300bhp? Unless because its FWD so the stress isn't distributed evenly.
Just a thought. How well does those ciplak 4 point harnesses work compared to stock seatbelts?That is why need to do complete mod, not half way.....hhahahhahaha
---------- Post added at 07:27 PM ---------- 6 hour anti-bump limit - Previous post was at 07:26 PM ----------
Won't know until you test them...Now who will be test dummy:hmmmm:.....hahahaJust a thought. How well does those ciplak 4 point harnesses work compared to stock seatbelts?
You and Chew already pointed it out. 4WD vs 2WD. AWD vs FWD. Very different physics man.C99 if same with Evo 1 then shouldn't have issues ripping at 300bhp? Unless because its FWD so the stress isn't distributed evenly.
Why would you bother. Harnesses need an anchor. So you'll probably gonna need to harness yourself to something like a bar at the back (which you don't have at the moment). It's fugly and overkill seriously. Get a full bucket first then only consider a harness.Just a thought. How well does those ciplak 4 point harnesses work compared to stock seatbelts?
Stock is 16mm la. Even if it was thinner it's not that much of a difference with 16. 19 and above will definitely be felt. But if comfort is what you're looking for, you probably don't need anymore than stock. 19mm will affect comfort to a certain extent.On this C99, I have fender bars, 2pt alloy front strut bar & Stiff Rings installed front/rear. Planning to upgrade the rear ARB. This car doesn't go on track. So no need for 23mm unit. Indecisive whether to get 16 or 19mm units. Or should I stick with the stock ARB? Any suggestions? The taman where I reside has numerous road humps. Have to consider the comfort factor. I occasionally drive to Genting. Upgrading the ARB will help address understeer. Recently the Genting road added many new thickish lines (speedbreakers). The drive up was okay but the Wira didn't enjoy bouncing over them on the way down. Not sure if foaming the side sills will help. Will find out on my next trip.
It firms up the rear and changes the characteristics of the rear grip. But if you're going to go to fTuned suspension then don't bother. If you're going to keep stock suspension then you'll feel it. Whether it's worth the boot sacrifice, depends on how hard you drive and how often you drive it hard. You don't need it for daily driving.@^pomen_GTR^, I noticed you didn't mention rear tower strut bar. Does it mean you find them 'not that useful'? I am contemplating it but still unsure if I want to sacrifice boot space. Any feedback on this will be greatly appreciated.
Expect extreme differences in comfort levels with coilovers. Regardless of what people tell you - stock is the most comfortable setting. Coilovers will stiffen any ride regardless of what spring rates you chose. But if you're like me and get used to it, soft and spongy suspension is very meh for me. I prefer firm and predictable suspension over comfort. I hate soft and uncomfortable plus unpredictable suspension.Come to think of it. If I had made these changes before buying the Preve, I might not have made the purchase. :hmmmm: Weighing less, the Wira traverses road humps better. Definitely zippier than the Preve. Currently also thinking of getting FTuned coilovers but that's another dilemma. After last round of autofoam, I'm happy with the current ride. Worried if the coilovers will ruin the honeymoon. Normally I would wait a few months; get used to the autofoam before deciding if I need coilovers but GST (Gomen Suka Tax) is coming. If I buy now, it will be cheaper. Any thoughts gentlemen?
---------- Post added at 04:32 PM ---------- 6 hour anti-bump limit - Previous post was at 04:25 PM ----------
