issuzark
Like you always say, no replacement for displacement.......hahhahhahahaha
Hell yeah. Now that I drive a 2.0L, 1.5L just won't do it for me anymore...
4G63 swap!
4G63 swap!
You cannot unless illegal.....hhahhahahha
4G63T transplant in a C91 chassis is just asking for trouble. Accident, cannot claim assuming you survive. That chassis was not designed for that much power either so expect it to crack over time. Nose heavy too.
I've seen a C99 Putra chassis crack with a 4G93 NA modded car. 4G63 in a C91? Good luck seriously.
But since you're gonna go illegal, might as well spot weld the chassis while you're at it.
Did that car have added aftermarket bars or any other measures taken to stiffen the body; specially in the front section of the car.I've seen a C99 Putra chassis crack with a 4G93 NA modded car.
Go big or go home? True that. It's already illegal so I might as well do some spot welding, and foams to increase the rigidity as well just for good measure?
That being said, isn't a Putra running 4G93 stock? How much NA mods did it have?
Thanks for sharing.front cross member area had tears (don't know the actual name of the area but it was near there) and everytime the fella revved can physically see that tear flexing.
yeah, I feel the fender bars are particularly important. Mind sharing what other steps you took to stiffen the car? I recently autofoamed my side sills. Car is so much nicer to ride in now.no worries...Ultra racing got all bar we need...
my c98 satria 1.6 auto already crack worrrrr.... old car...normal penyakit...
If going illegal, why stop and spot weld, add iron bar and strengthen.....lol
---------- Post added at 04:56 PM ---------- 6 hour anti-bump limit - Previous post was at 04:55 PM ----------
The Rally one or street one......Rally sure crack loh.....hhahhahahhah
Add iron bar? Still a street car for daily drive mah...
roll cage!!!
roll cage!!!
Hmm .. would it not possible to custom a roll cage to be hidden within the ABC pillars?Bro. Izso, Bar in engine probably can hide. Fit Roll cage, you know who get shot first.....hhahhahaha
4G93 NA mods with some cusco bars here and there. This was when UltraRacing was still new in the market. Spot welded chassis, solid mounts and stripped. On wheel it was over 300bhp+ and even with LSD it was twitchy. I never drove it because the owner was relatively short. Had a full bucket with modded brackets to cater for his height. As for the mod list, it was extensive to put it mildly. Without the standalone the idle speed was 1k-2k-1k-2k-1k God knows how he drove it like that for the time without the standalone.
The funniest story about this car was his bumper canards were installed at an overly aggressive angle and during sepang, the front bumper snapped off. The fella claims over "downforce" the front
Anyway in the end car was scrapped I think, or was it sold? The front cross member area had tears (don't know the actual name of the area but it was near there) and everytime the fella revved can physically see that tear flexing. If he did sell the car, I pity the new owner. It would only be a matter of time before the car becomes condemned. Hopefully the new owner was smart enough to demod and use normal mounts. Too much stress to the chassis la I think.
No place to hide....
Thanks for sharing.
Still we shouldn't place all the blame on the engine upgrade. With more power available, the desire to speed increases
The driver behind the wheel has to share some of the blame. Chassis damage results from aggressive driving. Stuff like extreme corner Gs or high speeds over undulated surfaces. The chassis is severely flexed. Over time, this flex translates to permanent damage.
Referring to the attached picture of Proton Suprima. Note that some bars align to the pillars.
I don't mean a full fledged roll cage with tubular bars but perhaps modify a bit using flatter, slimmer tensile ones which can later be hidden with the pillars' plastic covers. Roof has ample space to add tubular ones. It's a bit like reinforcing all those pillars and connecting each to the strengthened roof. Should act similar to a light duty roll cage. Likely won't need to wear a helmet driving this.
He He .. with those bars added, car will be heavier. No more pickup :damnmate:
Edit:
LOL .. don't mind me. After re-reading this post, I feel as though my head got knocked on one of those bars. :stupid:
Similar threads | |
