4g13 (Satria) Modification... Need suggestion of my MOD...
sugizo_takuro
71
10
1,508
NO... if JPJ know this, by roadblock, Puspakom test or whatsoever, your car will be pull straight to the JPJ yard...then you will suffer... dont trust mechanic that they will chisel and punch back the engine number the same as the original.. it cannot be done.. puspakom will easily know the difference.. it is their daily job bro... just change the block then register... pay extra money is better than lose your car...
S16
64
508
Melaka
thx dear friends... With al comments and suggestion, i gt a good and better ideas... Tq guys... And what is the procedure for that before and after changing, jz wanna do it in correct and legal manner... And cost of it.,
Depends. If you're changing the block, you'll need to go puspakom for inspection and register the engine block number with JPJ. Same goes for auto to manual conversion.
If you're turbo charging, no need to do anything la. If it's just stroking, reboring, injectors, etc.. these mods are low profile and no need to be registered.
It's coming near to Raya and Puasa, so if you change exhaust, make sure it's not overly loud or big big tip. Sure kena in blocks.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
if can do it legally... if not do it diam diam... dun la announce here n there.... tiny engine dun give people so big hope laa... later everyone wanna drag with u waste petrol laa....
Risis
12
1,503
getting piggy back and fine tuning your car also can help improve pick up and FC :idea:
Nov 28, 2007
Hi All,
Just to share of minimal mods i did to my 4G13P (vdo) with 4.5k in total. Original state: stock and the mods as below:-
1. Change piston (high comp) 1.4
2. Super Touring 1.6 flywheel (need to sent factory mod the lubang) + heavy duty clutch
3. Jasma Racing Cam+Adjustable cam pulley
4. Lighten (inner) main pulley (as VDO outer crank pulley slightly diff)
5. Management system (EMS-1)+dyno+tuning (tuned for mid range and high end)
Remarks: Gain additional 30hp after finalize it with item (5).
Fuel Consumption: better than before and better performance..
sugizo_takuro
71
10
1,508
i can comment to this mod. i had done to my 1.5 car.. bought the s/touring and skimmed the flywheel a bit.. can feel more pickup and extra torque.. change gear with less rpm than before.. even in highspeed, when accelerate, the pickup is good than before....
DanzEterna
15,910
3,371
3,213
PJ
www.primeperdanaclub.com
just wondering can 4g13 use 1.8 touring clutch set + flywheel? need to mod lubang? u guys mentioned that 1.6 super touring need to mod lubang, how much it costs?
BRclutch
Specialist in racing, general clutch, etc.
2,836
19
5,138
Ipoh, Perak, Malaysia
now no need to send to foundry dy, we hav ready stock, with heavy duty pressure cover n semiracing organic disc.....LoL...
---------- Post added at 01:09 AM ---------- 6 hour anti-bump limit - Previous post was at 01:04 AM ----------
Hi All,
now no need to do all those trouble stuff, we hav already made set for such Modification...less cost, less time....no need go chop factory to find super touring flywheel....plus we give 1 year warranty...
---------- Post added at 01:36 AM ---------- 6 hour anti-bump limit - Previous post was at 01:09 AM ----------
super touring total clutch set include flywheel got two type, FF n FR type.. the FF type can fit nicely to 4g13/15, but it weights 14kg more the ori 4g13/15 flywheel which is jes 10kg, no need modify holes becos it already hav 8inch clutch set holes. the 4g13/15 is 7.25inch, diaphragm thickness 2.0mm, super tuoring 2.2 mm, heavy duty cover2.3-2.4mm,
to buy a supertouring flywheel need rm150(market price) to reduce the weight to 10kg need foudry 3hours or one day work, cost rm80, to buy another set of new 8inch clutch set (normal Exedy or els brand)to replace the old 7.5inch will cost RM185(dealer price).
total cost RM415.......duration 2days of run here n there....
buy a BR clutch 4g13/15 upgrade kit cost RM350(exclude delivery) duration 1day of posting plus is factory made product plus warranty 1year.....
is not tat i wanna sel my stuff, jes we all motorsport enthusiast, we already create a better n faster way for u guys, y go through all this trouble...really dun get it....
kaderAE101
88
14
1,508
K.L / Ampang
Hi Bro..
I have read that modifications can be divided into 3 areas.
1. Electrical Efficiency -- Grounding cables, higher spark ign coil, etc
2. Thermal Efficiency -- Control heat.. make sure using the correct Spark Plug Heat range, etc
3. Volumetric Efficiency -- Piston compression, cam advance, free flow exhaust without enlarging pipe diameter & k&n filter, etc
If you work on efficiency, you can get better FC. But if your mods for raw power, then have to pay with Fuel..
For eg. If you guys try Cam Advance not exceeding 10 degree .. the pick up is good ... consumption improves.. !!
When did you last change the fuel filter ... ???
saweet999
May 10, 2011
35
508
what you mean by " fit in a 4g15 block"? you bring a complete 1.5 engine and put it in? how can u just put the block in? you keep the pistons head from the 1.3?
S16
64
508
Melaka
Thx for ur suggestions and sharing experiences... hope this will help all newbies...
---------- Post added at 06:28 PM ---------- 6 hour anti-bump limit - Previous post was at 06:26 PM ----------
correct....... ops sana sini...hahaha
for the 1.6 clutch set u can come to me n purchase our ready make 1.6kit for 4g13/15....this is the link...u can check it out....
http://www.zerotohundred.com/newfor...nce/83511-1-3-1-5-convert-1-6-clutch-kit.html
Thx for u all guyz...
saweet999- Jz replace 4g15 block, change the piston according to ur preference bro... :driver:
---------- Post added at 06:29 PM ---------- 6 hour anti-bump limit - Previous post was at 06:28 PM ----------
Hi Bro..
Alrite bro... Havent changed my fuel filter bro... Cuz jz recently bought the car...
---------- Post added at 06:30 PM ---------- 6 hour anti-bump limit - Previous post was at 06:29 PM ----------
Hi All,
NIce mods bro... Same like I did for my wira, except for the high cam... Jz curious with the brand and quality... :biggrin:
cowa
25
1,503
for a city car use, better remain to original 1.3 flywheel with a little skimming and stock 1.3 clutch set.. less strain to engine due to large mass of bigger and heavier flywheel and clutch set.. the mass of bigger piston and crack may can be balance with lighter transmission setup.. just my 2 cent
1.the rvr drive shaft can not fit into wira body right?currently the rvr haftcut tht i get is auto...so got ppl say tht i need to replace it vf the evo drive shaft.but the evo drive shaft got lsd and non lsd..so witch one should i use?
2.if v use the evo digital airconditions controler .v need to change the whole set blower to digital set o use manual set and jz the controler is use digital?and the evo bolwer can fit into wira deshboad?
hape u all can help me....thx u.
