so you're the one who bought from Ganga?using a customized cam brought over from a friend for 4AFE....
can feel the increased power but like some say, i think 7AFE is a better shortcut.
Bro... If BOT also have to use fuel regulator, piggyback etc la...I'm a fan of 4AFE. But If you want power from this engine just turbo it instead of trying on cams.
If want to buy cam, then have to buy adjustable pulley, then have to buy fuel regulator for more fuel at the higher rpm the cams going to give you, then have to buy piggy back to tune everything, then have to go to shop to tune it. easily the budget
Afraid that after all that money spent, when you test friends car with just 7AFE swap (cost $1200++) 7AFE feel more powerful.
My 4AFE is nearing 400 000km already. But no mods. I'm saving money for blacktop(when my 4AFE finally dies,if ever).
You should concentrate upgrade your brakes, suspension and tires first.
Good luck modifying..
hahaha... I got a customer who got 4AF carb and mileage at 800k++ also no die le... all running smooth.waiting for 4A-FE to die...? Slowly wait la...
why la.. i all so wan to get a 20v bt.. on what kind of money is it going to ?:hmmmm:But once conv to 20v, handle it with care ok...else its gonna hurt your wallet...a lot!
Just my 2cents
More parts sure more maintenance. The 20V has a lot of power but if you do more city drive, the low end torque feels slightly lower than 4AFE. This is due to high cams and larger intake ports. Theoritically it should be a little thirsty city drive compared to 4AFE. But my friends who use it reports good FC. So this is busted. Maybe the difference is very small only so cannot notice.why la.. i all so wan to get a 20v bt.. on what kind of money is it going to ?:hmmmm:
facepalm.jpg :stupid:nnik,
One of my fren bought the FE cam from them and it is not really plug n play. The best part is when you asked them duration and lift, they can only tell u 272 the rest dunno. Gulp..!!
Hey bro.... I've been trying to do this for a long time... But people told me cannot... Can you please advise more? You mean you got the engine only? As in engine lantai? Don't you need a halfcut for that? Because all the while mech told me if just engine only cannot. A lot of things don't have. How about the power steering pump, aircon pump etc? If you get engine only, what else have to source separately?for all the money to get the cam-fuel regulator-piggy- etc, y not just take a BT 5-speedengine with wiring only? get mine done for 2.4K(engine)+installation 1K(include new timing-belt and engine oil)
