gooday!
Car has been so well, thats why I forgot to post here!.. he he he he
Everything is completed, thanks to the internet, mechanic, Tuner, and exhaust shops for bringing my idea and other brilliant ideas into reality!
conclusion:
180whp (176-184 to be more precise, different dyno varying figure)
1.5way aftermarket LSD, really makes the car turn, and not turn! if you know what i mean
2-way exhaust cutout with electric valve, love it on the highway, and silent in the streets
No power steering, no A/C
Aluminium airbox with CAI (custom made)
SuperPro Bushes all around
18mm ARB with superpro bushes
Volk Racing TE-37 15 x 6.5
TITAN Monotube Suspension cant remember spring rate its been more than 4 years now
Endless Pads all around (blue)
Stock satria 1.6 calipers, stock disks(not a fan of cross-drilled or slotted mind me). no probs so far with stopping
PRO RS steel braided teflon brake hoses
AUTOMETER Oil Pressure Gauge, Full sweep electric, Phantom II, takes care of monitoring your oilies
Aluminium Radiator, local made
Oil cooler. filter relocator, steel braided plumbing.
hytech-style header imported from USA (unlike local ones which are much heavier and shorter)
Integra TypeR intake manifold
Skunk 2 composite fuel rail (ITR)
s90 70mm throttle body
whale penis intake filter
390cc fuel injectors (4g93t)
Port n polished head (nasty)
Jun type 2 cam and valve spring
H-Beam Duratec Rods, (the only aftermarket option at the time)
JE Piston
stock bearing
no oil squirter as originally planned
balanced crank, flywheel
4point front ultra racing strutbar, 3 point rear, room bar, 3point fender bar
quick shift (popular japanese brand, cant remember name) ITR shift knob, rethreaded shift pole
Defi Link Meter; speed, oil temp, water temp, defi RPM meter
quick release steering + short bush kit
sard fuel pump
rear battery relocation
Innovate Wide Band
Megasquirt2 standalone ECU (the best and cheapest out there)
battery cut-off switch, (marine quality, heavy duty) ??
cant think of anymore mods now..
enjoy the specs! if i could improve anything, pls let me know :)
