Really ah...???!!!
Hehehe...no need to do that la. That'll be just a gimmick like in those TV commercials. Even for the above test I also have some reservations (until I've done some more reading/testing myself or somebody can explain to me in more details). Pouring alcohol onto a surface and setting it on fire would only burn the alcohol that's evaporting ABOVE the surface. The temperature generated on the surface itself is nowhere near the temperature of the flame. Best test would be to burn the thing from the bottom....like cooking it...hahahah...
Discussion/rebutment is welcome....
Yes a better test should be cooking it or using a butane torch straight to it, but I think that temp is a touch bit too high. Googling showed that a blow torch flame at 1600C and the melting point of sio2 is 1600 to 1725C. But since our coatings aren't 100% siO2 anybody want to try? But what does the test reveal, it just reveals that the more Sio2 the product has the higher the melting temp will be until its 100% sio2 which will melt at 1600C. So if you cook it and it starts to burn, you know it doesn't have alot of sio2. That is presuming 22PLE is using sio2.
At the end of the day what does it really matter? If the coating looks good and is easy to apply and you are happy with it so be it lah.
Any coating sure water mark, it will sure get mirco marring still, and stain (just a matter of more or less), so I don't see the big fuss. I really doubt that coatings can stand up to mirco marring because the dust and sand we get on the car remember is made of quartz as well and other stuff like brake dust etc etc and is of similar hardness or higher. Even your windscreen can get scratches and micro marring and that's pretty hard glass as you need cerium oxide to do glass correction and anybody has tried to do glass correction, its damn hard as the glass is so damn hard.
So in the end I don't really bother about all these test, as long as its easy to use, and minimizes, maintenance, looks good, and solves my problems associated with my paint and my type of colour on that particular car I don't care who makes it or what its made of I'll buy it and use it.
Since we are talking 22PLE here I haven't tried it but would like to try it, just based on the looks and easy of use.
